I posted this in the swap meet by mistake.....oops. I will be needing an outboard for my Catalina 25. Can any one advise me as to a make, model, size; electric, or pull start? Maybe even where to look for a good buy.
You're looking for 8 to 10 hp. Most important thing to get is an EXTRA-long shaft (very commonly listed as 25").
On the 2 stroke or 4 stroke issue... depending on where you live, 2 srokes may not be available (due to pollution laws), they smoke a bit, but on the other hand are lighter and simpler. Use of 2-strokes are prohibited on certain bodies of water.
Electric startint adds a bunch of weight, is convenient, but is not essential if you/partner are in decent shape. Also desirable, but not essential is a 'high-thrust' model... they have a bigger propeller and are geared lower to offer better thrust at lower speeds. (better control).
Nissan/Tohatusu has a new 4-stroke long shaft that is being used by a few members. Haven't seen any negative reports on it to this point. It is considerably lighter (about 90 lbs) than the other new 4 strokes... which weigh in near 120 lbs and need extra-heavy duty motor mounts.
Other than the Nissan, your mainstream outboard choices are Honda and Yamaha. Note that the idle jets on the new 4 strokes are very sensitive to contamination. Clean fuel is a must.
Used outboards with extra-long shafts are out there... notably the Honda 'Classic' BF-8 4-stroke and the Evinrude Sailmaster (a 2 stroke). As these are starting to age it may be getting hard to find one in good shape.
It really depends on where and how you sail. If you’re on a lake, then a 6hp long shaft is plenty. The Nissan/Tohatsu 6hp 4 stroke is only 55 lbs and my little niece can pull start it. If you sail on the coast (or Great Lakes) in choppy conditions, then you might want to consider an 8hp with the x-long shaft. The 8hp 2 stroke only weighs around 50-60 lbs. Both engines give you plenty of thrust to get in and out of the marina. The 8hp will get your boat up to hull speed, approx. 6.2 knots, while the 6hp will top out at 5.5 knots.
I would stay away from the heavier motors if at all possible. The C25 wasn’t designed for them and to use them you’ll need to replace your motor mount, beef up your transom and get a couple guys to help you remove your motor at the end of the season. Sailing performance will also be adversely affected by the extra weight. When I replaced my old 100 lbs Mariner with the 55 lbs Tohatsu, my stern lifted over an inch higher out of the water.
If you want a good web site for checking outboards try http://www.iboats.com. I’m admittedly biased towards Nissan/Tohatsu, but I wouldn’t recommend the Hondas, based on the postings on this site (do a search) and on IBoats.com.
One other thought on the electric vs manual start issue - if your home waters are a freshwater lake, get electric start. If your boat is located in salt water, don't get electric start unless the motor also has a rope pull starter like the Honda or Yamaha 8's. Salt water will sooner or later cause corrosion problems with the electric starter, either in the motor itself or in the cable connections that feed power to it. And of course if you get an electric start outboard, you commit yourself to making sure the boat's battery charge is maintained reliably. so that you don't arrive at the boat for a weekend outing and discover you can't start because the battery is low. Cranking a starter motor - in your boat or car engine - with a weak battery is bad for the motor, by the way, causing excess heat in the windings since the motor isn't getting the full voltage it was designed for and is thus not being operated at it's most efficient rotation speed.
