I notice that my boat sits in the slip with the bow down. The water line is a good inch above the bottom paint. There's no water in the anchor locker, and I've taken all the stuff (including the cushions) out of the forepeak. Is there somewhere else where water may be collecting? The water tank is empty.
The only other think I can note is that my Nissan 8 is a lot lighter than my old Evenrude 8.
Bruce Baker Falls Church, VA "Yee Ha" 3573 '83SR/SK
Bruce, We experienced the same thing with our 78 SK. I raised the keel and then she levelled out. We keep her at dock with the keel down so when we realized why she was pointing down it never really bothered us that much. Also sit at the tiller and have someone check to see if with the keel down and your weight in the back does she level out. Good Luck.
We used to have a swinger as well. When the keel is down, the bow goes down. Lots of weight held onto a very small bronze pin a bit to forward. No worries.....better to keep it down
As long as the cockpit drains OK, there's nothing to worry about--a crew in the cockpit will put her on her lines. Or, you could get a Honda like mine! (If that doesn't do it, try the Merc Bigfoot 4-stroke--it's a monster.)
Have a person sit in the cockpit. Then you go and stand back from the boat and look at the water line. Should be more "balanced". Better to have the boat balanced while sailing for better performance underway then in the slip.
Ditto on my early SK... wether by accident or design, the early SK's don't sit level unless you have the keel cranked up. Last haul out I added a bit to my bottom paint to keep the growth away. I crank my keel up about 1/2 way at the slip. (not much wave action where I'm at)
My '79 (hull no. 1205) was a swinger and also sat bow down. My '89WK Mk. IV, (hull no. 5857), sits perfectly even fore-and-aft, but lists 2 to 3 degrees to port, which seems to be an almost universal condition of Catalina 25's of all model years and interior styles, even when the owners have made every possible effort to move weight to the starboard side.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by lcharlot</i> <br />My '89WK Mk. IV, (hull no. 5857), sits perfectly even fore-and-aft, but lists 2 to 3 degrees to port, which seems to be an almost universal condition of Catalina 25's of all model years and interior styles, even when the owners have made every possible effort to move weight to the starboard side. <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote"> The C-25 is a "narrow" boat. The slightest imbalance, like the galley, will cause a list. So, she'll be a tiny bit faster on port tack.
