 Winch Maintenance Help
LeighMarie
Initially Posted - 07/23/2004 :  23:44:44  Show Profile
I guess it's about time to take my winches apart to clean and relube. You all have probably done this before but I have not. I have 2 Lewmar 16-2 speed winches that sound noisy. I also have a Lewmar Winch Maintenance Kit. The question I have is that it says on page 28 to clean the components in a paraffin bath. If that isn't available you can use a cloth soaked in paraffin or white spirit. Does that mean I should melt down some candles and put the components in there? That just doesn't seem right. Or, is white spirit the same as mineral spirits?
Also, the Kit has Racelube in it. It says in the instructions to use a light engine oil on the pawls. Is that the Racelube? The other tube is GearGrease which is what I presume I use on the gears, ratchets, etc.
Lastly, what is the brush in the Kit for? It says it's a Lubricating Brush, but I'm not sure what to do with it.
Thanks for any help you could give me!
Dave & Sharon on "Leigh-Marie"
Hull #5128
Response Posted - 07/24/2004 :  00:16:36  Show Profile
Paraffin is the English term for "Kerosene". White spirits... essentially paint thinner.
Lightnup
Response Posted - 07/24/2004 :  08:56:14  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Paraffin is the English term for "Kerosene". White spirits... essentially paint thinner.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
Glad I got up this morning...I learned something I didn't know yesterday.
Steve
Gloss
Response Posted - 07/24/2004 :  10:54:03  Show Profile
When I serviced all 4 of my winches earlier this year I used mineral spirits to clean the parts. I blew out the excess with my nozzle on my air compressor, let dry some more in the sun. I lubed the parts with the lube (for the pawls) and grease included in their kit. I figure if it was in their kit, they want you to use it. I only lost one pawl spring, good thing the kit has spares.
Now they work really smooth.
RichardG
Response Posted - 07/24/2004 :  11:22:58  Show Profile
It's helpful to have an old toothbrush to clean the parts in the kerosene or mineral spirits bath.
The Lewmar rep at this year's Rendezvous recommended 3&1 oil on the pawls and springs -- grease on everything else. If your Racelube is a thinner, clear liquid, it's for the pawls and springs.
The brush is for applying a thin layer of grease to all the internal parts' surfaces (except the pawls and springs). Get a square sheet of aluminum foil and fold it half twice, then squeeze a glob of grease onto it -- this "painter's palette" allows you to put just the right amount of grease on the brush in order to get a consistent, thin layer of grease on all the parts.
I just serviced my winches (without getting a kit) for the first time after getting a quick lesson from the Lewmar guy. It was pretty simple (after getting over the fear of various parts flying into the water) -- only lost one of the pawl springs, but luckily I performed that operation inside the cabin and a 10 minute search recovered the spring.
While I previously had no troubles with the winches, they are a bit quieter now -- probably good for another 12 years.
Edited by - RichardG on 07/24/2004 11:25:58
nate
Response Posted - 07/24/2004 :  11:32:33  Show Profile
To avoid dropping stuff.....I took a shallow box and cut a hole the size of the drum and taped the box to the combing. This creates a shallow "tray" to catch stuff that might come loose while you disassemble the winch. The pawls and their springs are the only things that could take a swim and you should have spares in your rebuild kit anyway.
LeighMarie
Response Posted - 07/24/2004 :  12:15:25  Show Profile
Thanks for the help! I may get to it next week.
ronrryan
Response Posted - 07/24/2004 :  18:15:15  Show Profile
If you dont have kerosene or mineral spirits you can use some spare gasoline from your outboard tank, etc. Yes, it is bad for your skin, but its handy and if you take care youll be fine. I just did a couple of Barlows that way, Ron srsk Orion sw fl
PZell
Response Posted - 07/25/2004 :  11:09:06  Show Profile
Used a box as a catcher. Coleman fuel as a cleaner. 3&1 oils for the
pawls. Put Lewmar grease on drums with my finger. No sweat. After the first one you realize how easy it really is.
