 galley faucet
pierrem
Initially Posted - 07/29/2004 :  10:16:05  Show Profile
I am in the process of "shocking" my water system. It hasnt been used in a number of years.
I filled it up last night...very slow to take water....faucet in head worked great....faucet in galley is inop.
Anyone replace or repair. difficult? procedure?
thanks
Pierre
frog0911
Response Posted - 07/29/2004 :  10:38:47  Show Profile
Parts are availble from WM and other places. They are simple to repair, mainly cleaning and "O"ring changeout or replace completely at more expense. You might just take it apart, clean everything then put some petrolieum jelly on the O-rings, reassemble and give it a try. It worked for me a few times on our old boat
Buzz Maring
Response Posted - 07/29/2004 :  10:50:46  Show Profile
Hi Pierre,
As Jerry mentioned, you might be able to take the old one apart, replace an O-ring or two, etc. and get it working again ... that is a much cheaper proposition than replacing it altogether.
My old galley faucet was beyond hope, so I had to replace it ... here's what I used:
You can read about it here: [url="http://www.westmarine.com/webapp/wcs/stores/servlet/ProductDisplay?storeId=10001&langId=-1&catalogId=10001&productId=13115&catalogId=10001&classNum=74&subdeptNum=27&storeNum=11"]Galley faucet[/url]
Installing it was no problem ... it fit into the hole that the old one came out of. I haven't finished rebuilding my freshwater system, so I can't tell you how it works yet. I CAN say that the Evil Empire has gone up $10 on the price since I bought mine (just over a year ago).
'Hope that helps ... good luck!
RichardG
Response Posted - 07/29/2004 :  11:46:31  Show Profile
Pierre -- I think the head sink was an option. Some (but not all) who have this option rarely, if ever, use it, and just use the area for storage or convert it to a hanging locker. You could take the working faucet from head and put it in the galley sink (which may be more likely to be used). You could then, at your leisure, repair the bad faucet, take the sink out, etc.
It's also possible that both faucets are good, but the supply line to the galley sink is pinched. Switching the faucets as above would confirm this.
Good luck.
Ben
Response Posted - 07/30/2004 :  07:48:13  Show Profile
Hi Pierre,
I tackled this same problem myself last year, and before I bought anything I removed the galley faucet and took it home to try to diagnose the problem in a controlled (my kitchen sink) environment. Turns out the faucet worked fine. The problem was the little screw clamp (don't know what they're called) that held the hose to the bottom of the faucet had worked loose over the years and was letting air in, interfering with the suction of the pump. I was very pleased that I didn't have spend any money.
Good luck with your faucet.
pierrem
Response Posted - 08/03/2004 :  22:37:36  Show Profile
thanks to all...upon further investigation. I was able to get it to operate...tightened etc.
thanks to all
Pierre
