 Full Batten Main Questions
megrier
Initially Posted - 07/30/2004 :  10:04:09  Show Profile
I have heard that full batten mains are very difficult to raise and lower. The issue seems to be that regular sail slugs will not slide freely with the added wieght of the full battens. I was told that you need cars with rollers instead of sail slugs. I have never heard of or seen cars with rollers.
Also, I was told that full batten mains are not as efficient in light air because they tend to stay too flat.
Does anyone have any experience or comments on these issues?
Thanks!
rclift
Response Posted - 07/30/2004 :  10:51:14  Show Profile
Having changed from a partially battened main to full battens I found no difference in how the sail set. Replacing mast head sheeves and lubricating the sail slot may make it easier to raise and lower. The major benefit of full battens is in lighter air where the battens keep the sail in a more efficient shape.
matsche
Response Posted - 07/30/2004 :  11:42:10  Show Profile
The full batten main will go up/down just as easy as the original partial batten main without any special slugs, at least on our sized boats. The full battens will also extend the life of your mainsail.
Bruce Baker
Response Posted - 07/30/2004 :  14:49:41  Show Profile
I bought a fully-battened main from Catalina Direct and love it. It has excellent shape in light air, and there's no issue with raising or lowering it. It's got a bit more sail area than my stock main.
Brooke Willson
Response Posted - 07/30/2004 :  15:20:08  Show Profile
I have two full battens at the top of my new main, and partials below. I've discovered that the full batten has to be raised and lowered pretty much dead into the wind -- any significant sideways pressure on the slug will make it hang. Other than that, it's terrific.
Brooke
Response Posted - 07/30/2004 :  15:36:04  Show Profile  Visit Frank Hopper's Homepage
My full batten raises and lowers off the wind with no problem. In light air you can even retention the battens to build a deeper pocket into the sail. In other words your advise was not appropriate to our boats. (40 ft boats have the cars and they are very cool.)
nate
Response Posted - 07/30/2004 :  16:46:45  Show Profile
I agree with all above. The full battens on a C25 mainsail aren't heavy enough to warrant cars that aid in setting the sail. I have a FB mail from Ullman that is awesome....I even went up a size (1/2") in sail slugs (because I was tired of breaking the cheap plastic ones in heavier air) and I've had no problems with the sail binding in the track.
oldsalt
Response Posted - 07/30/2004 :  16:55:29  Show Profile
Full battens, on boats like ours, present none of the problems of which you were told, in fact, they offer many advantages as stated above. I'm enjoying my second season with my loose footed, full battened, Ullman main and its a terrific sail. You get a more efficient shape in light air, excellent sail shape control, and the sail won't flog itself to death when you motor into the wind. Raising and lowering the sail presents no problem at all.
megrier
Response Posted - 07/30/2004 :  17:07:48  Show Profile
Thanks you guys!
It sure is nice to get some feedback like this before you jump in to something!
Greg
frogger
Response Posted - 07/30/2004 :  20:12:24  Show Profile
It makes a huge difference if you lubricate the sail slugs with a silicone lubricant. You should have no problem raising/lowering unless something is binding.
Response Posted - 07/30/2004 :  22:19:58  Show Profile
I find that with my full batten main that I have to be head to wind to hoist otherwise the batten slugs jam. It's also easy to get a batten stuck under the spreader. Having said that, I wouldn't have any other form of mainsail.
Derek
roberoo
Response Posted - 07/30/2004 :  22:54:54  Show Profile  Visit roberoo's Homepage
I changed to a full batten main this year. I have lazy jacks and they get hung up if I not in irons. But I wouldn't change it for anything it makes sailing in light wind much easier for me.
