 Arrgh Fishfinder woes [:(!]
D Wrate
Initially Posted - 07/31/2004 :  15:02:57  Show Profile  Visit D Wrate's Homepage
So I am finally getting around to installing our fish finder, a Humminbird PiranhaMax 15. Problem is I cannot get it to read through the hull. In the water works great gets a reading in seconds, in the hull in a baggie of water, on a baggie of water... no reading...
This is the second unit as the first one read erratically even over the side. I know a shoot thru will work as the transducer for the old flasher is still there in a pvc tube and worked fine.
Hull is solid glass approx 1/2 to 5/8 in thick.
Last resort is to try the toilet bowl wax ring trick...
Any other suggestions?
Frustrated in Sidney...
David
S/V Cindino
wade
Response Posted - 07/31/2004 :  23:45:34  Show Profile
Try putting mineral oil in the pvc tube rather than water, that is what I used.
Response Posted - 08/01/2004 :  18:03:41  Show Profile  Visit Frank Hopper's Homepage
My Hummingbird transducer is epoxied to the hull in the small bilge access. Works fine.
D Wrate
Response Posted - 08/02/2004 :  01:09:31  Show Profile  Visit D Wrate's Homepage
Well just got back from the boat where I tried unsuccessfully to get this fish finder to work. This time I crammed it into a baseball sized gob of wax right next to the existing transducer and....nothing happened. Just a big zero on the display... over the side... 17 ft in a heartbeat... power off.. back in the wax... nada...
I might see if the existing transducer can be made to work with this display...
David
jwilliams
Response Posted - 08/02/2004 :  11:01:35  Show Profile
David,
I have a Horizon epoxyied to the inner hull aft of the fin keel.
I was having some intermittent problems with consistent reading. I checked the manual and learned about sensitivity (gain) adjustments.
Occasionaly now I can get a false reading when I am really heeled, but I think that is bubbles (or a really big fish right under the sensor )
Jim Williams
Hey Jude C25fk 2958
SF Bay
D Wrate
Response Posted - 08/02/2004 :  11:06:27  Show Profile  Visit D Wrate's Homepage
Should there be more or less sensitivity?
David
jwilliams
Response Posted - 08/02/2004 :  17:36:22  Show Profile
David,
Dunno, without looking at your manual, sorry.
Jim Williams
Hey Jude C25fk 2958
SF Bay
ronrryan
Response Posted - 08/02/2004 :  20:39:27  Show Profile
You do not mention whether you have the bottom painted with antifouling paint. Some paints will interfere with the "shoot-thru" on the hull, a problem I have had in the past. Sometimes a bit of scraping just below the transducer location will allow epoxied-in pucks to work again. Good luck, ron srsk Orion sw fl
RichardG
Response Posted - 08/02/2004 :  20:44:55  Show Profile
I've been trying for about 4 years to get my fishfinder to work. I get intermident successful readings in a couple spots, but nothing consistant. Someone once suggested that my hull may have imbedded microscopic bubbles which were trapped when the hull was manufactured.
As you know the old transducer works in its spot, you may want to remove it and put the new one in the PVC pipe.
oldsalt
Response Posted - 08/02/2004 :  21:09:48  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by D Wrate</i>
<br />Should there be more or less sensitivity?
David
My guess is that you should increase the sensitivity and see if that helps to penetrate the hull.
D Wrate
Response Posted - 08/03/2004 :  00:41:49  Show Profile  Visit D Wrate's Homepage
I have exchanged the Humminbird for an Airmar depth sounder, no fishy images anymore... also going to see if the local marine electronic wizard can make my old transducer work with the new display. He had told me a while back that if they were both 200 khz (new display is, old transducer likely is) there was a good chance they would work.
Will keep you posted
Thanks all!!!
David
Keith Dennis
Response Posted - 08/11/2004 :  14:20:16  Show Profile
Check out Tech Tips for the C25 and scroll down to the boat name "Nakomis". He installed his transducer in a PVC pipe attached to a flat part of the hull, placed the transducer inside filled it with mineral oil and capped it with the lead wire comming out of a slot in the cap. I think I am going to try this as I am getting far out readings. I know my slip isn't 56 ft.
