I recently purchased a Catalina 25 and I am needing to purchase a different engine for it. I am looking at a late model 9.9 Evinrude Yachtwin with electric start and alternator. The 4 stroke model weighs 110 lbs. I was wondering if anyone knows what the mounting bracket weight range specs were. Thanks!
That's what I have on Hey Jude, long shaft version. Its a heavy sucker.
My engine mount is the original, tube-type Garhauer mount. It has been rebuilt with bronze bushings, larger diameter bolts, helper springs (see the tech tips section) and thicker side arms. Also, reinforced inside backer made from 7/8 in plywood.
There have been extensive postings on alternative engines and mounts. I think the hot set up is the Honda 8Hp 4S long shaft right now. Look in the archives or someoneanother of our brothers will tip you to the right site.
The Garhauer web site says the capacity of their retractable engine mount is 125lbs. I recently replaced my original Garhauer mount with a new one. As someone on this site recommended I used the stainless mounting angles off the old mount as backing plates inside the hull to help distribute the load. I have a 2004 8hp Honda extra long shaft with electric start hanging on it. The owners manual says this motor weighs about 117lbs. I believe it! I've been keeping a close eye on things and so far no problems.
Another issue with hanging really heavy motors on the Cat 25 transom is "oil canning" of the relatively thin fiberglass. If I were going to mount an outboard weighing more than about 80 pounds, I would install a 16" x 12" piece of 3/8" thick aluminum plate or 3/4" thick Starboard between the transom and the motor mount to spread the load.
Show me a Catalina 25 whose transom "oil cans" under the load of an 80 pound outboard and I'll show you a Hunter or a Mac.
However, to effectively strengthen the overall transom structure in the event that a heavy 4 stroke engine is installed, any reinforcement plate would need to be installed as a backing plate on the inside of the transom between the motor mount nuts and the transom, where it can absorb the strain of both the additional static and dynamic loading imposed by the weight and thrust of a motor which exceeds that originally recommended by the factory.
But for any conceivable 2 stroke outboard, let alone one weighing 80 pounds, save the Star Board for cleaning fish.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by oldsalt</i> <br />...to effectively strengthen the overall transom structure in the event that a heavy 4 stroke engine is installed, any reinforcement plate would need to be installed as a backing plate on the inside of the transom between the motor mount nuts and the transom, where it can absorb the strain of both the additional static and dynamic loading imposed by the weight and thrust of a motor which exceeds that originally recommended by the factory.
But for any conceivable 2 stroke outboard, let alone one weighing 80 pounds, save the Star Board for cleaning fish. <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote"> I disagree... A large part of the force imposed on the transom will be inward against the lower edge of the bracket, due to the weight of the engine, the leverage of the bracket, and the thrust while in forward gear. An equal force is outward against the upper bolts holding the bracket. The inner lining and outer transom were not designed with these 100+ lb. high thrust engines in mind, and the light foam core between my transom and liner won't contribute anything. I've seen some denting (not exactly oil-canning) on C25 transoms at the bottom edges of the brackets, with lighter engines than mine. That suggests plates on both sides--not just one. I used Starboard for an outer plate that extends well below the bracket, and an inner one that extends as far as possible above it. I'm pleased with the solidity.
Dave I agree that ideally, if one wants to beef up the transom area, backing plates should be installed on both sides, particularly if there is a foam cored liner there.
On my '83, Silver Girl, the transom has no inner liner and therefore, no foam core. My transom is solid GRP with a rather heavy mat roving lay up (not chopper gun stuff) and a large area of extra layers of heavy mat extending well beyond the motor mount area.
I have a '96 Sailmaster 2 cycle weighing around 90 pounds, hung on the stock Garhauser mount, and my transom shows no sign of canning or weakness at all.
However if in the future I decide to replace it with a heavier 4 stroke, I'll beef up the transom with plates on both sides as well as upgrade the mount just to be on the safe side. But with my current setup, my transom is stiff as well as rock solid.
I got a 2005 Yamaha 8 HP instead of the 9.9 Evinrude. It is electric start with alternator and weighs in at about 105 lbs. I am going to put plates on both sides just to be on the safe side as well. Thanks for all the good advice!
I am not sure what the actual physics/engineering are. But earlier this year I followed what Frank Hopper had done to his boat and put a sandwich of starboard and a Garhauer mount on the transom. It is holding up the XL shaft 9.8 4 stroke Nissan motor and I use it at 3/4 throttle pushing the boat at about 6knots with no problems. I also put a starboard backing plate inside the transom.
