 engine bracket question
cmckitrick
Initially Posted - 08/09/2004 :  08:52:58  Show Profile
Is there a trick to locking the motor mount in the down position? I havent fully investigated it but the two times I've shifted to reverse the motor lurches forward. Thanks.
Charlie McKitrick
Norwell, MA
Valiant Lady... for now
'81 C 25 SR/FK
RL
Response Posted - 08/09/2004 :  10:31:50  Show Profile
Charlie,
Depending on your type of mount this may be incorrect but my has a locking slot in the mount. A bar that slides up and down with the motor is pulled into the locking slot by a small spring. Check/replace your spring. However even if the spring is not working properly, you and manually side the bar into the locking position to keep the motor from moving when in reverse.
If you can pass along your type of mount, it would help analyze the problem.
RL
oldsalt
Response Posted - 08/09/2004 :  18:08:39  Show Profile
It looks like you're talking about the reverse lock on your outboard rather than your motor mount. What kind of outboard do you have? You need to make sure you flip the tilt selector into the locked position instead of the tilt position. You should try to tilt your motor after you lower it. If you can tilt it, it will kick up when you run the motor in reverse.
cmckitrick
Response Posted - 08/10/2004 :  07:48:47  Show Profile
I'll try that. I have a mercury 8 hp. It seems when it kicks up the motor bracket moves up as well. Thanks for the help.
Response Posted - 08/10/2004 :  08:53:12  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Oldsalt</i>
<br />It looks like you're talking about the reverse lock on your outboard rather than your motor mount. What kind of outboard do you have? You need to make sure you flip the tilt selector into the locked position instead of the tilt position. You should try to tilt your motor after you lower it. If you can tilt it, it will kick up when you run the motor in reverse.[quote]
<i>Originally posted by cmckitrick</i>
<br />I'll try that. I have a mercury 8 hp. It seems when it kicks up the motor bracket moves up as well. Thanks for the help.
On my 8hp Merc, the tilt locks automatically when the throttle is turned/shifted into reverse and is released when the throttle is turned in the forward direction.
