 Rope Designations
frich
Initially Posted - 03/04/2002 :  11:27:10  Show Profile  Visit frich's Homepage
Has anyone developed or come across a universal color scheme for all ropes on a C25 that I may apply. I understand red/green combo but what about Spinakers,Jib vs mainsail, outhaul, lazy jacks etc?
Response Posted - 03/04/2002 :  12:19:09  Show Profile  Visit Champipple's Homepage
Whatever suits you. Even the red and the green have no meaning on some boats when it comes to running rigging. I have easily stepped on board over 100 boats...there is something different about each one...
Just make sure that you know and won't get confused. If you run any lines aft, you may consider labeling the clutch cleats...
Duane Wolff
"The Flying Wasp"
C-25, #401 std,sk
Chief Measurer C-25/250 national Org.
<img src="http://im1.shutterfly.com/procserv/47b2dc20b3127cce9cd2f45b211a0000004010" border=0>
John Mason
Response Posted - 03/04/2002 :  13:05:59  Show Profile
I don't know if there is a universal color scheme. I just bought color coded lines, but the scheme only applies to my boat.
Blue for the main sail:halyard-white w/ blue flecks; sheet-white w/ blue flecks(came with the boat); jiffy reefing-blue w/ white flecks; topping lift-solid blue.
Green for the jib:halyard-white w/green flecks; sheets-solid green.
Red for spinaker(the sail is red):halyard-white w/red flecks; sheets-solid red; tack line-red w/ white flecks.
John Mason - Ali Paroosa
1982 - FK/SR #3290
Response Posted - 03/04/2002 :  17:47:25  Show Profile  Visit Leon Sisson's Homepage
I don't know of any standard line colors, but here's what I'm doing:
Mainsail controls to starboard, headsail controls to port.
Spinnaker halyard: 3/8" white w/blue. (to port winch & line clutch)
Jib halyard: 3/8" white w/red. (to port winch & line clutch)
Main halyard: 3/8" white w/green. (to line clutch)
Heavy air jib sheets: 3/8" solid red port, solid green starboard.
Light air jib sheets: 5/16" white w/red port, white w/green starboard.
Spinnaker pole lift: 5/16" (or 1/4"?) solid blue. (to line clutch)
Mainsheet: 3/8" solid blue.
Main vang: 1/4" solid green (6:1)
Main downhaul (cunningham): 3/16" (or 1/4"?) white w/green (4:1)
Main traveler: 1/4", maybe solid black (in work now).
Backstay tensioner: 3/16" white w/blue.
Flag halyards: 3/16" magenta port, teal starboard.
Jack lines (for harness tether): 3/8" both solid black.
Anchor rodes: 3/8" white w/gold braid, 7/16" white braid, 1/2" white 3-strand.
Still working their way up the "To Do" list:
Spinnaker tack line: 3/8" (to port winch & line clutch).
First reef: probably 1/4" white double braid. (to line clutch)
Second reef: probably 5/16" white solid braid. (to line clutch)
Outhaul: 3/16".
Boom topping lift: 3/16".
Ben - FL
Response Posted - 03/04/2002 :  21:49:27  Show Profile  Visit Ben - FL's Homepage
I always make my mainsheet solid red. I thought it generally always was solid red.
I'm wanting to use some different colors also. I figure I'll use red & white for the main halyard. Solid blue for the jibsheets and blue & white for the jib halyard (even though the jib is on a luffspare(is that the right term?(are there too many parentheses in this sentence?)))
And while we're on the subject, I've got two lines coming out the boom. Are they both supposed to be jiffy reef lines, one for the first reef and one for the second?
Safe voyages,
Ben, FL s/v Chick-a-pea C250wk
Douglas
Response Posted - 03/05/2002 :  20:35:14  Show Profile  Visit Douglas's Homepage
I guess if your color blind you cant sail.
