Not that I can think of a reason why I would ever want to remove my soon-to-be-installed bronze thru-hulls, but I'll stay away from the polyurethanes just the same. Polysulfide sealant seems to be the correct choice here? Finger tighten thru-hull by hand until the sealant cures, then make snug with a wrench while not squeezing out the sealant. Comments, suggestions, hindsights . . .
Yes, they cure as a reaction to moisture in the air. Higher humidity (higher temp.), faster cure. But apply them to dry surfaces. Also understand that they can take up to 7-10 days to fully cure.
FROM PRACTICAL SAILOR-------------------------------------------- The polysulfides cure slowly compared with other marine adhesive sealants, with the one-part formulations generally taking significantly longer than the two-part compounds. Although the compound should be applied to a dry surface, polysulfides will continue to cure underwater, and boats can be launched with mechanically fastened fittings bedded in partially cured material. In an emergency, polysulfides can even be applied underwater, but this should be considered a temporary fix rather than a permanent solution. ------------------------------------------------------------------
