I've not heard the term "jackline" used specifically with regard to single line reefing gear. Can you quote the source?
In my experience, a "jackline" is generally the term given to a line that lies on the deck from bow to stern. Sailors secure the tether from their safety harness to the jackline so that they can easily (and safely) move around on deck during foul weather. This "jackline" is often a rope or small SS wire......or -now- more often 1" nylon strapping that lies flat on the deck.
There is an old sailing term - "jack rope" - that refers to the line that secured a sail to a yard arm or other spar. In that framework, I wonder if your "jackline" might be the line that ties up the reefed sail to the boom.
The luff slides on your sail that are near the reef grommet will prevent the grommet from being pulled down tight to the boom for reefing. The solution is to put the slide on a piece of line that is passed through the shackle that would normally hold that slide. The line is then fastened to another location lower on the sail so that when the luff is pulled tight the slide is held in its normal position. I will try to take a picture of ours and post it tomorrow. Dave
Hi Steve The excellent photos from Dave Bristle show a double cringle arrangement for the sail slides that you might not have. My 83 has single gromets. There is a very clear drawing from the C25 Tech Manual that shows the mainsail jackline arrangement. If you email me your USPS mailing address, I'll photocopy it and send it to you. The drawing calls for a 1/8" dacron line. I used a metric one a tiny bit larger, but less than 3/16", and wish I had followed the instructions. The line tends to bind up in the sail slide bail and I have to be careful each time the main is raised to make sure the line is running freely before final tensioning with the halyard winch. As a rigger once told me, "The winch always wins." The single-line reefing works really slick and I have successfully shortened the sail both close hauled and running in 12-15 kts. When going to windward, heaving to allows me to get the last of the slack out of the line from the main's reef clew gromet aft to the turning block on the boom. Not having to leave the cockpit when singlehanding is a real plus. Hope you enjoy it. Best regards, Jack 83 FK/SR 3944 Rag Act
Hi Frank Great pictures, as always. Very pretty. I'm wondering - since you have the wide slot in the mast blocked so the sail slugs can't fall out, why do you have the jacklines? Is it becasue the slugs tend to hang up on the keepers screwed on the mast while you're reefing? Just curious. BTW - Since I am new to the C25 this year, I was really impressed with the way the boat sailed with a single reef in the main and the working jib. Close hauled, when the wind picked up past 15 kts, I put in the reef. When it slacked off back to about 10 kts, I was too lazy to shake out the reef, but the boat speed didn't seem to suffer, according to the knot meter. I don't have wind speed/direction, so these are just estimates. Best regards, Jack 83 FK/SR 3944 Rag Act
The jack line allows the sail to fall away from the mast and boom so the slides do not stack on bunched up sail. Notice how tight my foot is, and how low the reefed tack is, that is what they do for you, they really clean up the goose-neck area in a reef. They also allow that large single mass of sail to act as a sail cover when your sail is on the boom. It is hard to explain but after you lower the sail you just grab the jack line area of sail and haul it over the top and it covers everything, a quick tie or two and you are done. Of course at the slip you put your cover on.
