 Knotmeter
JoergK
Initially Posted - 10/19/2004 :  16:25:46  Show Profile
I have to replace the "paddle wheel" sensor. What would be the best sealant?
Joerg
2002C250 WK "BerLyn"
Sea Trac
Vanuatu
Response Posted - 10/19/2004 :  16:44:10  Show Profile
Hi Joerg,
Normally no sealant is required for the sensor other than an O-ring, because the sensor screws down into the top of the through-hull fitting which is sealed independently. Generally, the paddle wheel transducer is constructed this way so that it can easily be cleaned at the beginning of each season and removed for the winter. You should have a plug that looks just like the sensor sans the paddlewheel and wire. The plug is used to seal the through-hull while the transducer is out, and both should have rubber O-ring fittings.
Alan Clark
Response Posted - 10/20/2004 :  10:54:04  Show Profile
Joerg, I have just put alittle vaseline on it to make it SLIDE in smooth and keep the Oring fresh.
Shelby
Response Posted - 10/21/2004 :  08:31:28  Show Profile
There is also a lub that you can use that is used for O rings on swimming pools and spas.
