 New boat = Many questions
tbader
Initially Posted - 11/30/2004 :  10:43:21  Show Profile
After stalking a 250 for 2 years, and lurking on this forum for a similar amount of time, I have finally gotten a hold of a 250 WK of my very own.
Thanks to the contributors to this forum for helping me with my decision.
Now to the first of my (many) questions:
1. Hull Number: the HIN is CTYA0430F900. So this is Hull # 430, built in January (F) of '00. Is this correct?
2. Battery: My first boat ('69 Cal 20) had a plug for a solar charger to keep the battery charged ("trickle charge") over the winter. Is there a way to create a similar arrangement on the 250? If not, what should I do w/ the battery over the winter?
Thanks in advance.
Tom Bader
2000 Cat 250 WK
Riverton, NJ
Tom Bader
2000 WK #430
'Deliverance'
Riverton, NJ
Buzz Maring
Response Posted - 11/30/2004 :  11:08:51  Show Profile
Hi Tom,
Here is a link to a site that explains how to interpret your hull number ... I think you've got it right ... [url="http://www.boatsafe.com/nauticalknowhow/hin.htm"]Hull numbers[/url]
Congratulations on your new boat, and welcome to the group!
zebra50
Response Posted - 11/30/2004 :  13:32:55  Show Profile
Congrats on the boat. During the winter I take my battery home and keep it in the basement so it wont freeze. During the year while docked, it is hooked to a continuous charger also tied in to shore power for two outlets on board (w/GFI).
Tom Potter
Response Posted - 11/30/2004 :  18:01:50  Show Profile
I have 2 12v sockets located in the combing pockets, one on the port and one on the starboard. On the port side I have the wires run to a charge controller that is mounted on the aft bulkhead and then wired to the battery. I use this for the solar panel. The starboard side socket is wired to the main switch panel I use it for other 12v stuff.
Welcome aboard! I've had my 250WK for 3 months now.
Jeff McK
Response Posted - 12/01/2004 :  13:53:46  Show Profile
Tom,
Welcome to the group. These folks are a terrific resource.
Since you are in New Joisy where it actually gets cold in the winter, I'd agree with Zebra50: Take the battery home & put it on a "smart charger" so you don't cook the battery. Just make sure you have good ventilation & keep it away from the furnace (hydrogen gas+fire=Boom!)
Here's a string I started earlier this year when facing the same question. You can click on the link or do a search for "smart charger" in the files.
http://www.catalina25-250.org/forum/search.asp?mode=DoIt
Response Posted - 12/01/2004 :  17:38:16  Show Profile  Visit Frank Hopper's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Jeff McK</i>
<br />
For some reason this is the first time the end of that string has read Doit, I always thought is read DOLT and assumed it was an editorial comment on my searches.
Jeff McK
Response Posted - 12/01/2004 :  20:30:50  Show Profile
Tom,
My apologies, but for some reason the link I posted does not want to work for me. No idea why this is so. Maybe I left off some critical punctuation soewhere. Has anyone else been able to open it?
In the meantime go to the search link & type in "smart chargers" if you want to see the info.
Frank: I thought mostly the same thing you did, but that it was a dig at the posting person.
