 Whale pump
George Beck
Initially Posted - 12/14/2004 :  14:47:03  Show Profile
Does anyone have E-mail address or phone # for company making the WHALE PUMP which was installed in most or all Catalina 25s galley sink? I have parts list from 1984 listing mfg as Munster Simms Engineering LTD(an English Mfg), and probably distributed thru SEAGULL MARINE in Irvine, Calif. That Phone no longer works nor can I find an address on the net for them. I know they used to have a repair kit available but have no contact at present. Any info appreciated. Next call to Catalina Direct if this dont work. Thanks in advance.
MattL
Response Posted - 12/14/2004 :  15:18:23  Show Profile
I tried to get a repair kit last year, but the west marine guy couldn't find it. After he and I poured through his paperwork the only thing we could find was that it and the repair parts were discontinued. The cheepest pump they had was about $60 bucks so I have that project on hold. Figurativly and liteateraly, got to hold the nozzle in or it squirts out.
Wildcat
Response Posted - 12/14/2004 :  16:03:40  Show Profile
I know there is a pump on ebay for less than twenty dollars a lot of the time. It seems the seller must have a bunch because it keeps coming up on the plumbing listings in boat parts. Not the same as our pump but it looks like a good sub.
clayC
Response Posted - 12/14/2004 :  16:17:29  Show Profile
Have you tried an RV store? I was looking some time ago and they didnt seem that expensive.
Clay C
Lightnup
Response Posted - 12/14/2004 :  16:45:53  Show Profile
Since whales have become endangered species, they can no longer be killed for their pumps...thus the shortage.
Anyhow, the top item on the attached link is what my '82 had in it when I bought it. They are in the price range that Matt mentioned but mine don't appear to be overly cheesy.
Steve
[url="http://us.binnacle.com/online/dept.asp?dept_id=2040"]Whale Faucet/Pump[/url]
Edited by - Lightnup on 12/14/2004 16:46:57
atgep
Response Posted - 12/14/2004 :  18:18:11  Show Profile
Here is the West marine part # for the service kit. It includes all the guts for the pump and made both of mine brand new.
WM#(142455) Add it to your cart and then you can check the local store. I found one kit at each of my local stores.
Tom.
Todd Frye
Response Posted - 12/16/2004 :  14:06:14  Show Profile
George,
Fix the sink pumps was one of the first repairs I did to my newly purchased boat, 5 years ago. They still work and don’t leak, which to me is a pretty good endorsement of the fix. I took a few days going back and forth to the local Ace hardware store, looking through their O-ring “station”. I’m assuming Ace is a national chain, and the part numbers should be the same, if your Ace has one of these O-ring stations ( plastic pull out drawers grouped together).
Spigot O-ring
11/32” X 3/8”
STK. NO. 388058
Pump Handle
Remove plastic nut and clean deposits on handle with Scotch Brite
Pump Handle plastic nut O-ring
51/64” X 41/64” X 5/64”
#80 O-ring
STK NO. 35714B
(Put this O-ring on pump handle first, with glycerin)
Large O-ring
9/16” X 5/16” X 1/8”
#31 O-ring
STK. NO. 35745B
The pump body does not need to be removed for this fix. Carefully remove spigot and handle and the worn O-rings will be visible. I applied a small amount of Glycerin to lubricate the new O-rings. Can’t remember the exact cost of 3 O-rings from Ace, but it couldn’t be more than $5.00.
Todd Frye
Dave Laux
Response Posted - 12/16/2004 :  18:46:08  Show Profile
You should throw away the pumps you are working with and replace them with foot pumps. That way you can wash both hands at once. Or a dish. Dave
MattL
Response Posted - 12/17/2004 :  00:47:28  Show Profile
Tom, that looks like the parts kit for the newer pump. Parts are different than in mine.
oldsalt
Response Posted - 12/17/2004 :  06:22:07  Show Profile
Two years ago I bought a new one from Sailnet for about 60 bucks.
Jonathan Cuff
Cayman Island
Response Posted - 12/17/2004 :  09:38:21  Show Profile
Lewis Marine stock it #4279-GP0418 or spars kit #9905-SK0405. It's called a Whale Flipper Pump. You can reach Lewis Marine on 800 327 3792.
Cheers Jonathan
Response Posted - 12/17/2004 :  21:55:12  Show Profile
I replaced my with a Fynspray--a much nicer unit that pumps as you push the lever both fore and aft. I recommend that over spending the time and $ to repair the Whale, or the similar amount to buy a new Whale. I can't comment on foot pumps except that I presume they will involve more installation than the Fynspray, which is a direct replacement.
Gloss
Response Posted - 12/18/2004 :  09:06:04  Show Profile
anybody out there using an electric pump system? Is it practical in our little boats?
Response Posted - 12/18/2004 :  11:29:59  Show Profile
"anybody out there using an electric pump system? Is it practical in our little boats?"
I've seen threads and photos on just that. (Arlyn?) Sure, completely practical. The pump's about the size of a soda can. 2 wires for the switch, 2 wires for the power, a few hose clamps and fittings... Bob's your uncle.
Response Posted - 12/18/2004 :  15:11:51  Show Profile  Visit Leon Sisson's Homepage
Frank,
I installed an automatic electric fresh water pump in my C-25. It was an easy upgrade, and it works fine. Along with it, I installed an accumulator and a strainer. Let me know if you need more info.
Buzz Maring
Response Posted - 12/18/2004 :  15:45:50  Show Profile
<br />Frank,
Hi Leon,
What's an accumulator?
Thanks ... Merry Christmas!
Dave Laux
Response Posted - 12/18/2004 :  16:23:55  Show Profile
Its like the pressure tank on your well pump. Its supposed to reduce short cycling. IMHO they don't do much for you except add to the cost. I like the Shure flow and Quadra jet pumps. Use 1/2 dozen /year with no problems. Both will send you the odd fittings that they use to hook up in limited spaces if you ask. Dave
Edited by - Dave Laux on 12/18/2004 16:25:51
Happy D
Response Posted - 12/19/2004 :  08:40:12  Show Profile
Found this 12V submersible fresh water pump. Put it in the tank and it won't take up and space.
Just a thought.
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=26449&item=4512558245&rd=1
