 Shelf Depth
ilnadi
Initially Posted - 02/23/2005 :  16:23:04  Show Profile
We are moving the electrical panel above the starboard settee (like Not Yet http://www.catalina25-250.org/tech/tech25/nypanel.html but definitely not as nice looking).
Two questions:
<ul><li>Does anyone know how deep the shelf is behind the starboard settee at the aft end? I forgot to measure the depth and I want to prepare some parts at home.</li><li>If you look at NY's panel, the back panel seems to be mounted at the top and bottom. I assume I do not want to screw or bolt into the outer hull at that point. Am I correct?</li></ul>
Thanks for the help.
Nadi ex-C25
http://www.sailblogs.com/member/enka
http://building-spindrift11s.blogspot.com/
Response Posted - 02/24/2005 :  08:59:03  Show Profile  Visit aeckhart's Homepage
I don't know the depth of the shelf off hand - probabley 4-5 inchesa at most.
You <b>don't</b> want to screw into the hull. Use glue and fiberglass matt to install the cabinet.
Al
GALLIVANT #5801
