 Keel leak - UPLOADED PICTURES
dalieva
Initially Posted - 04/14/2005 :  10:00:16  Show Profile
<font face="Verdana"></font id="Verdana">
These pictured are of the bottom leading edge of the keel. We realized we had a problem when I went to chip away some old epoxy and when I did water ran out of the keel.
I have no idea where this water is coming from or exactly how to fix it.
I currently have it left open to dry so I can refill it again with
epoxy. If you have any suggestions, it would be greatly appreciated.
Is it normal?
THANKS A LOT!
Randolph
[url=http://www.shutterfly.com/view/picture_dt.jsp?state=67b0de21ba3add333596&idx=0]
Edited by - dalieva on 04/15/2005 09:33:29
Response Posted - 04/14/2005 :  10:22:39  Show Profile
Your FTP site wants a login. What year/keel type is your boat?
JimB517
Response Posted - 04/14/2005 :  11:06:43  Show Profile  Visit JimB517's Homepage
if you can email me the photos, I can post them for you.
james.baumgart "at" sdsheriff.org
We'd certainly need to get a look at that keel. This is an unusual report.
dalieva
Response Posted - 04/14/2005 :  14:04:35  Show Profile
<br />Your FTP site wants a login. What year/keel type is your boat?
James will post the pics for us.
The boat is a 1984 fixed keel. We think the keel is made out of lead but we will confirm this weekend.
Thank for your help.
JimB517
Response Posted - 04/14/2005 :  15:11:59  Show Profile  Visit JimB517's Homepage
I have the photos and will post them tonight. It looks like a lead fin keel. I think the PO grounded pretty hard some time in the past, resulting in a big gash. This was filled and faired with epoxy. Water got under the epoxy. When you pulled the old stuff out, water came out. This is cosmetic damage only. You need to check the top of the keel (where it joins and is faired to the hull) and the keel bolts and keel well to see if there was any damage from the past grounding. Look for cracks in the back of the keel well or separation of the top of the keel from the hull (Catalina smile).
JimB517
Response Posted - 04/16/2005 :  23:52:28  Show Profile  Visit JimB517's Homepage
Photos
Edited by - JimB517 on 04/16/2005 23:54:03
JimB517
Response Posted - 04/18/2005 :  13:10:23  Show Profile  Visit JimB517's Homepage
Come on guys, please look at the photos. Can we get a little help?
Response Posted - 04/18/2005 :  13:39:23  Show Profile
I have a cast iron keel, and after a season of low water levels, it tends to get scraped and chipped similar to your photos (I hit bottom about 2 or 3 times last year). To fix, I grind the epoxy encapsulation down around the wound to get rid of any delamination, then put primer on the bare cast iron, fill with epoxy, fair, barrier coat, then bottom paint.
This will last me until the next grounding!
Response Posted - 04/18/2005 :  14:35:41  Show Profile
If it was my boat, I'd let it dry for at least a couple of weeks, then sand it just enough to scuff it. Then I'd wire brush it clean, to get rid of any loose materials. The important thing is to seal moisture out from between the fiberglass sheath and the lead. If there's any place where the sheath is separated from the lead, I'd try to fill that space, perhaps by injecting epoxy into it with a syringe and then holding the epoxy in there until it sets up. Then I'd put about 4 coats of coal tar epoxy on it, to seal it against water intrusion. Then I'd fill it with epoxy filler, fair it, barrier coat it (probably with about three more coats of coal tar epoxy), and then paint it with anti-fouling.
dalieva
Response Posted - 04/18/2005 :  17:06:26  Show Profile
Hi everyone.
Thanks for your help it is greatly appreciated. I think for this year it will be a down and dirty fix to get the boat in the water and fix it properly in the fall or following spring. But for anyone who may have something similar, we are thinking the water is coming from the bilge. So we are thinking of also sealing up the bilge as well. If anyone has any suggestions on a quick way of sealing the bilge it also would be greatly appreciated.
existentialsailor
Response Posted - 04/18/2005 :  18:51:43  Show Profile
I know Catalina keels are bulilt differently than my Capri, but I'd be concerned about water wicking up the fibers in the keel and causing other damage. I may be off base here, but I'm sure someone will chime in if I am.
JimB517
Response Posted - 04/19/2005 :  12:34:50  Show Profile  Visit JimB517's Homepage
What fibers? What leak from the keel well? Mine is a solid piece of cast iron. There is no fiberglass anywhere except fairing the keel to the hull.
The keel well is bone dry all the time (unless I've let water in from cleaning the knotmeter paddle).
The wing keels I've seen are also solid lead. No fiberglass.
dalieva
Response Posted - 04/19/2005 :  12:44:31  Show Profile
Hi Jim
I am not sure if your questions are directed to me or not but the keel is in capsulated by fiberglass. The cast iron keel is inside the fiberglass as you can see in the pictures.
existentialsailor
Response Posted - 04/19/2005 :  12:50:29  Show Profile
Guess I was off base Jim, my keel is encased in fiberglass. Didn't realize the Catalinas were made that different. His pictures didn't look like a wing keel to me either, but I'm probably just not looking at them right. If that thing is solid cast iron, that IS a weird problem. I'll go crawl back under my rock now.
Response Posted - 04/19/2005 :  13:28:08  Show Profile
Older C25 fin keels were crude iron castings. When I got mine, in 1981, it was coated with coal tar and the especially rough spots were filled with epoxy to smooth it out. In about 1983 or 1984, as I recall, Catalina started putting lead fin keels on the C25s. The lead was not exposed. It was encased in fiberglass, which made them much smoother than the cast iron keels.
Randolph and Dali's boat has the lead fin keel, encased in fiberglass.
I've never looked that closely at the wing keels, but believe they are exposed lead, not encased in fiberglass. That's one of the disadvantages of wing keels. Because lead is fairly soft, a hard grounding can bend a wing. I saw a Pearson with a bent wing. I suspect it would make the boat want to continuously make a gradual turn.
Edited by - Steve Milby on 04/19/2005 13:35:31
JimB517
Response Posted - 04/19/2005 :  15:45:09  Show Profile  Visit JimB517's Homepage
I've never seen a lead fin out of the water and did not know they were fiberglass encapsulated. If so, you are seeing the main problem with encapsulation, what happens after a grounding.
My cast iron is bare metal, but its been epoxy coated and covered with bottom paint.
The wings are lead and are not encapsulated.
OK, so here's what I would do.
Grind the area a little around the damage
Let it dry out
Mix up some Marine-Tex epoxy
Fill the hole
Let it dry
sand smooth
Apply bottom paint
go sailing.
Don't hit bottom again!
dalieva
Response Posted - 04/20/2005 :  12:47:47  Show Profile
Hi Jim
That's great. That is exactly what we intend to do this year and probably do it properly in the fall.
