 Jib hoisted over rolled up genoa?
Martin
Initially Posted - 04/14/2005 :  18:42:51  Show Profile
I have a 150 genoa on a furler. I need an easy way to hoist a smaller headsail without having to take the genoa off the furler.
What do you think about making a sleeve which would go over the furled genoa (something like a sail cover for a furled headsails), with grommets into which I could hank a jib?
Anyone heard of, or used such a thing? The closest I saw on the web is the ATN galesail, but I want this contraption for a normal jib, not storm jib. Thank you.
tinob
Response Posted - 04/15/2005 :  09:07:51  Show Profile
Hi Martin,
Of course it's doable though I don't understand the need if your furler is functional. Which begs the question, is your furler functional? Usually folks resist sailing with a furled genny because it effects somewhat the efficiency of the furled sail. Certainly a sail sleeved over the furled genny will be no better than the furled genny itself.
Val on Calista
Dockside 500/s34
Martin
Response Posted - 04/15/2005 :  14:43:08  Show Profile
Hi Val,
If it is doable, any thoughts on how or who/where?
I wanted to do this because, as you said, the partially furled genoa -- especially furled beyond just a few turns -- is not particularly pleasant to sail with -- I get more heeling and less forward speed than my wife cares for. I also worry that the unfurled part would stretch prematurely. I thougth a smaller sail hoisted this way would be a solution to both problems. Mabye not?
ilnadi
Response Posted - 04/15/2005 :  14:49:47  Show Profile
Check the archives for storm sail or stay sail. There was discussion about how to hoist a storm sail inside the headstay.
