 keel zincs
gerdo
Initially Posted - 04/09/2002 :  13:02:49  Show Profile
Will be keeping C25 swing keel in chesapeake bay this season, plan launch 4/30 and will keep in until mid december. There are no keel zincs on it. Should I put some on?
Response Posted - 04/09/2002 :  14:16:04  Show Profile
Gerdo,
Catalina Direct states on page 4.60 of the Catalina 25 handbook that,
"<b>Keel zincs are mandatory in saltwater</b>, recommended in freshwater to protect this entire assembly from electrolysis. Replace the zincs yearly. Zinc, a less noble metal, corrodes first and protects the iron, stainless steel, and bronze from corrosion."
That statement and the fact that the keel zincs only cost $11.50, I would say do it.
Don Lucier, Northstar
C25 SR/FK
gerdo
Response Posted - 04/09/2002 :  16:04:15  Show Profile
thanks for the reply Don. I assume I would drill the keel and through bolt the zincs.
Response Posted - 04/09/2002 :  16:31:58  Show Profile
Gerdo,
I assume so, but I don't know for sure since I have a fixed keel boat. Is there anybody out there with any advice?
C25 SR/FK
Bruce Baker
Response Posted - 04/09/2002 :  20:12:41  Show Profile
Gerdo,
I've just bought a swing keel boat myself, and noticed while painting the keel a disc about 4 inches in diameter on the starboard side, close to the pin. My guess is that this is where the zinc goes. FYI, I'll be keeping my boat in the Potomac after sailing it to Alexandria VA from Rock Hall, MD where it sits currently.
Ed Montague
Response Posted - 04/09/2002 :  23:06:45  Show Profile
My swing keel has a tear drop shaped zinc on each side of the keel about half way up. They are attached with machine screws into a threaded holes in the keel. Drilling all the way through the keel will be a chore. Just drill a hole about 1" into the keel and tap it. Be careful with the tap, cut partial turns and back it out and then cut some more and back it out, etc. Be sure to use cutting oil. Salt water boats need zinc and fresh water boats should use magnesium, fresh water is less conductive and magnesium is less noble. Having said that, my boat is in fresh water most of the time but I have Zinc anodes because I didn't know better and it seems to work. Next time I replace them it will be with magnesium.
Ed Montague on 'Yahoo'
gerdo
Response Posted - 04/10/2002 :  09:09:41  Show Profile
Now this may be a stupid question, but what material should the bolts be. Stainless, or zinc coated?
Buzz Maring
Response Posted - 04/10/2002 :  09:59:17  Show Profile
Hi Ed,
I'm dusting off a lot of brain cobwebs, but it seems to me that I learned from chemistry courses that magnesium <b>explodes</b> <img src=icon_smile_shock.gif border=0 align=middle> when it comes in contact with water ... did I dream that? (I never much liked chemistry anyway.)
Ed Montague
Response Posted - 04/10/2002 :  12:58:22  Show Profile
Gerdo, The screws that hold the anodes on are Stainless.
Buzz, Check page 473 in the 2002 West Marine catalog. Gives a good discription. However, you may have uncovered an evil plot to sink all C25 swingers.<img src=icon_smile_wink.gif border=0 align=middle>
f_sondergaard
Response Posted - 04/12/2002 :  12:34:21  Show Profile
For our 25 swing keel, we just drop over a zinc fish with a cable that we attach to our keel drum. about every eight months we replace the zinc fish. West Marine has this set up. We use this only at the dock! This works great for us, no holes to drill!!
Ken Cave
Response Posted - 04/14/2002 :  23:48:36  Show Profile
OK Folks: You can mess up your swing keel by putting zincs on it-and getting extensive damage to your trunk when you try to raise your swing keel-or not!!
I had my boat in the SALT water for a number of years without zincs and had no problems with the boat or any of its thru hulls.
Now, lets think this out!! What do you have in tha water that can possible eat away? A swing keel! What is it attached to it to conduct electricity? Nothing!!
Your engine? Yup, you have a problem there-but if you look at it, it has a zinc on it somewhere to protect it. And, if you are smart, you will raise your outboard out of the water when you are through sailing it.
You will do more damage in using an automotive battery charger on the boat in the water. That is why you must use a charger made for marine use!!
Ken Cave
Ken Cave
Response Posted - 04/14/2002 :  23:53:22  Show Profile
Gerdo:
If you have a fixed keel, chances are that you have some system grounded to the bolts on the keel. If you do not have an inboard engine with a zinc on the prop shaft, better be safe than sorry. Put a zinc on your keel just for preventive maintanence.
Ken Cave
MattL
Response Posted - 04/15/2002 :  09:40:44  Show Profile
Buzz,
If Magnesium exploded in water, the recent plane crashes in to the various bodies of water would have been much more explosive. Mg, is a very light weigth and strong material. The problem is that it can catch fire. That's why plane creashes do not have lots of debris. Also why some automobile fires are extreamly hard to put out, Mg engins. It is also the metal used in the old flash cubes.
I think the metal you are thinking of is sodium, over one spot on the periodic table with 1 electron in the valence level, Mg has 2, it is very reactive and will react with moisture in the air. In water it is quite spectacular.
there is your science lesson for the day.
Matt
EC Rider
Cat 25 86'
FK SR
Buzz Maring
Response Posted - 04/15/2002 :  10:29:08  Show Profile
Buzz,
... there is your science lesson for the day.
Matt
EC Rider
Cat 25 86'
FK SR
And a good lesson at that ... thanks Matt, the cobwebs are starting to part ... a little.
