 Preventing Outboard Theft.
sodonnell
Initially Posted - 04/30/2005 :  22:11:52  Show Profile
There have been several outboard thefts where I keep my C-25 in recent years.
For that reason, I generally stow my engine in the cabin.
It's a real hassle, I'm hoping to be able to leave the engine on the mount this season.
I'm wondering what everyone else uses to secure their outboard besides the standard masterlock setup.
Scott
Response Posted - 04/30/2005 :  23:19:12  Show Profile
This has been kicked around here quite a bit.
Remember, nothing is foolproof, all you can do is "slow 'em down" or discourage them.
Thread ideas in a nutshell.
Clamshell lock over mounting screws.
Quality cable lock looped through handle, mount, rails.
Bolt engine to engine mount. Use 'odd' spec bolts (allen, torx, left hand etc)
Make it an unattractive target with a 'custom' paint job, prominent lettering of boat name etc.
Wire in an alarm circuit. If the wires to the motor are cut, sound alarm, turn deck lights on etc.
Dunno if I forgot anything.
Buzz Maring
Response Posted - 05/01/2005 :  11:24:47  Show Profile
<font color="blue">... Wire in an alarm circuit. If the wires to the motor are cut, sound alarm, turn deck lights on etc. - Bruce</font id="blue">
Hi Bruce,
This came up in a thread a couple of months ago, but there were no details explaining how to do something like that. Is this the sort of thing that an electronically challenged person could do?
Thanks!
Response Posted - 05/01/2005 :  20:53:40  Show Profile
"electronically challenged person could do?"
Should be quite simple to do. I think that car or home alarm components could easily be adapted to create a 'motor theft' alarm. The wire to the motor forms a simple 12V loop that supplies voltage to a NC (normally closed) relay. (Voltage supplied to it holds it open). If the circuit is cut the relay closes, which turns on the alarm. Probably comes as a 'prefabricated' kit...
power to alarm, loop to motor and bob's your uncle.
Response Posted - 05/01/2005 :  21:08:35  Show Profile
Or you could use one of those personal alarms that are about as big as a pager and are activated by pulling a lanyard connected to a pin. They emit an ear piercing sound and I think you can get them for around $15-20.
Edited by - dlucier on 05/01/2005 21:09:01
Sea Trac
Vanuatu
Response Posted - 05/01/2005 :  23:06:03  Show Profile
I was Googling for the high-voltage boat "fence" protection package when I discovered [url="http://aqualarm.net/store/boat-security.asp"]Aqualarm[/url]:
Although, I still want to install a high-voltage, proximity "alarm".
"Move your smoking carcass away from the outboard."
seastream
Response Posted - 05/03/2005 :  04:19:57  Show Profile  Visit seastream's Homepage
As Clam said, all you can hope for is to slow 'em down or discourage them. Locks really are to keep honest folks that way. Above all, insure your engine for replacement cost, if possible.
Bob...back from London
atgep
Response Posted - 05/03/2005 :  07:45:16  Show Profile
I don't make mine TOO hard to remove. I would rather have a missing motor than a broken transom. Of coarse I have an older sailmaster.......HMmm 4 stroke........................
Tom.
tinob
Response Posted - 05/03/2005 :  12:37:42  Show Profile
It's been my experience that you don't want to present a challenge to thieves. Some thieves just can't resist a challenge. It 's like their calling demands of them that they circumvent any and all obstacles placed in their path. Some years ago the boaters on Neguntatoque creek were experiencing an alarming number of thefts of outboards from boats in the water. A fellow with a brand new speed boat and one of those inline Mercuries thought to protect his new rig by through bolting everything to the transom, chains and such. To some it appeared to be fool proof and for a while it was. Until the challenge was accepted and the motor was chainsawed off the transom.
Motor gone..boat sunk..
The advice to be adequately insured is about it.
Val on Calista # 3936
Brooke Willson
Response Posted - 05/03/2005 :  17:04:36  Show Profile
1. Insurance is cheap when you need it.
2. Dock your boat bow in, so it's harder for thieves to get to the motor. Not impossible, but harder.
3. No one seems to be interested in my 20 year old Mariner 2 stroke. After the fact that it still runs perfectly, that seems to be a good reason to not replace it unless absolutely necessary.
Brooke
ronrryan
Response Posted - 05/03/2005 :  20:44:31  Show Profile
I once bought a trailerailer with a nice Mariner motor. I painted the motor duckboat drab camoflage and put on the clamplock unit. No problem, even though others were targeted. Motor ran perfectly, despit "nasty" paintjob, regartds, ron srsk Orion SW FL
georgiaboater
Response Posted - 05/03/2005 :  20:48:42  Show Profile
I agree.....Bow in.....with the lock bar key down...so at least there is some amusement/knowledge in knowing the thieves were trying to drill out the lock on the back of the boat in the normally choppy waters of the sound where it is slipped.
Response Posted - 05/03/2005 :  22:57:17  Show Profile
I use the machine thread version (see link below) to "secure" my outboard motor to my motor bracket. One special tool for the screw head and another for the nut.
http://www.tamperproof.com/index.cfm?fuseaction=products
I've never put a lock on my outboard . . .
Charlie Vick
Response Posted - 05/04/2005 :  08:48:27  Show Profile
A couple years ago a few determined souls anchored about 100 yards ouside our cove, donned scuba gear and proceeded to swim up under the marina. Their goal? To steal as many lower units off I/Os that they could get. I think the count was 11. A daunting task for sure but at several thousand dollars a piece it was well worth their effort.
Just goes to show, if they want it bad enough they'll take it.
Insure and secure enough to deter theives but not enough that they damage you boat getting it off. IMHO
Luckily I have an old Evinrude 7.5 which isn't worth anything to anyone but me so I haven't had any problems. (Now comes the sound of knuckles rapping wood!)
MikeM
Response Posted - 05/04/2005 :  12:57:53  Show Profile
I use a real basic approach. Buy a lock wire that you woul duse on a bike, with open ends. Wrap it around the railing base on the stern and thread it through the handle on the motor. Get your self a good brass lock (oil it up) and you are all set. I leave mine locked all the time, even when running becuase the wire is long enough.
seastream
Response Posted - 05/05/2005 :  21:22:04  Show Profile  Visit seastream's Homepage
I also have to agree with Brooke and Atgep. My current engine is a 1987 'Rude 9.9 2 stroke that still starts on the first pull. I think the current market value is around $200. That alone may dissuade thieves. I'd love to replace it with the Nissan 9.8 four stroke, but as long as it's cheap, ugly looking, works, and appears not worth stealing...
Bob
Happy D
Response Posted - 05/19/2005 :  21:54:36  Show Profile
I found this while I was looking for something else. Alarms that are activated by the removal of canvas snaps. They also have accessories for the theft prevention of outboard motors.
http://www.canvassnapalarm.com/
Response Posted - 05/20/2005 :  08:55:53  Show Profile  Visit Champipple's Homepage
Unfortunately, if they want it, you aren't going to stop them, only make it difficult.
Getting to know your neighbors is always a good thing, every eye you can get looking after your stuff always helps. I used to have a 1979 Johnson 9.9. It was insured for replacement value of $1000 even though it was worth about 100. Back then I all but hung a sign that said please steal me. Now that there is a 1 year old electric start alternator 8 hp tohatsu sitting there I am a little more concerned.
I agree with most - if you make it too difficult its a challenge and a lot more than a replacement motor.
Make sure its on your insurance.
Gambit
Response Posted - 05/20/2005 :  12:20:28  Show Profile
My father taught me that a lock only keeps the honest people from stealing something. I just have the clamshell over the mounting screws for my Johnson 9.9. Just hope for a good neighborhood and with alert people and make your boat harder to rob than another one.
Response Posted - 05/20/2005 :  19:41:25  Show Profile
I have an outboard lock installed, but it would be easier to simply cast off the docklines and sail the boat away.
tinob
Response Posted - 05/21/2005 :  10:02:43  Show Profile
Don you're the MOST usually thinking outside the box. Some motor theives,however set up shop in their garage, arranging the motors here and there. Your thief would have difficulty competeing with the average guyunless he organized an in water boatshow.
Happy D
Response Posted - 05/22/2005 :  20:37:36  Show Profile
So there is something to be said for the old Zephyr Saildrive after all.
Can't steal that, and, who would want to?
I knew there was a benifit to using this motor just took me a while to figure it out.
