 quarterberth-access hatch
glivs
Initially Posted - 05/03/2005 :  17:14:14  Show Profile
The teak access hatch at the aft end of the starboard quarterberth on "Great Escape" has proven unaccessable. I assume one normally lifts the hatch upward and pulls the bottom inward, but shy of applying enough pressure for something (teak, fiberglass, me)to break I have been unsuccessful, although one of the two vertical members just clears with a little force. I also assume that gaining access will allow me to check/replace the lower rudder gudgeon. Any thoughts/suggestions? I am not sure even how the hatch could have been installed. I considered shaping and slipping a hacksaw blade up behind the teak to shorten the vertical member causing the problem, but thought it best to consult your combined experiences first.
Thanks in advance.
Response Posted - 05/03/2005 :  17:37:17  Show Profile  Visit aeckhart's Homepage
Gerry,
Don't recall having this problem. usually it's a lift and pull situation. Since the hatch goes in axactly opposite of coming out, give it a good pull. Heck, it's only wood.
You'r correct. It gives you access to the lower gudgeons.
Al
GALLIVANT #5801
ronrryan
Response Posted - 05/03/2005 :  20:47:26  Show Profile
Maybe it has swelled? Been jammed by some PO? Mine comes out easily, sounds like something a bit wrong rather than a fixed unit. Keep tinkering, Fair winds, ron srsk Orion SW FL
Response Posted - 05/03/2005 :  22:38:49  Show Profile  Visit Frank Hopper's Homepage
Mine has to rotate a bit either clockwise or counterclockwise and then it lifts out. It will not come out without the rotation.
thacket3
Response Posted - 05/04/2005 :  10:06:29  Show Profile
I had to loosen the screws first, then I was able to pull up/ out. It was maddening.
glivs
Response Posted - 05/04/2005 :  21:10:35  Show Profile
Thanks all...hopefully this weekend will try again.
