That, like most other anchor questions, depends. if the bottom is mud and the anchorage is protected, 150# with heavy chain should be OK. In a more open anchorage, move up to 250#. Up here, some people use large granite sinkers when the bottom is ledge. These sinkers can weigh several tons. There should be 3-4 X Max depth of heavy chain, with lighter chain to the float, plus a decent length of 5/16" to 3/4" line to the cleats. A lot depends on how tightly the harbormaster packs the mooring grid. Helical mooring systems that are bored into the bottom are the most secure, and are beginning to be required by some harbormasters in storm-prone harbors up here in the NE. Also, I have seen another system of 3 heavy Danforth-type anchors set out at 60 degrees to each other and connected at a central point, from which the chain goes to the float. Do allow for storm surge when calculating the length of the chain; I have seen moorings dragged when the pull from the vessel becomes straight up & down on the mooring and it has been pulled out of the bottom.
