 CRACK IN KEEL - "GREAT ESCAPE"
greatescape
Initially Posted - 05/09/2005 :  12:55:18  Show Profile
My '82 Catalina 25
Has a 6" horizontal crack .(I think it's where the iron ballast meets the fiberglass)
It was filled a few years ago by former owner when I bought the boat.
The crack seems to appear every year and I grind a small bit and then patch.
Any suggestions to prevent a recurrence? What's happening? should I check the forward keelbolt?
Scott " Graet Escape"
Scott
JimB517
Response Posted - 05/09/2005 :  13:29:46  Show Profile  Visit JimB517's Homepage
Ah yes, the "Catalina Smile"
Response Posted - 05/09/2005 :  13:57:16  Show Profile
If it recurs after being patched, that means it's moving a little bit. I'd try torquing the keel bolts down a bit and then patch it again and see if that helps next year.
greatescape
Response Posted - 05/09/2005 :  15:02:33  Show Profile
Thanks Jim
I'll Check out keel bolts.
Scott Stevenson
tinob
Response Posted - 05/10/2005 :  12:38:10  Show Profile
Scott,
Some fins had their keel bolted to a plywood base and over time the wood deteriorates and causes the "SMILE". The advice to torque the keel bolts was right on. Hopefully the keel bolt nuts are still doing their job. If all is as should be torquing the bolts to specs should wipe away the smile. If it doesn't then the possibility of a decaying keel base is likely. I hope not and don't want to get ahead of myself in considering that condition and it's cure.
Val on Calista # 3936
