OK, time to show what a real newbie sailor I am. How do I tell the difference between a whisker pole and a spinaker pole? Or are they the same pole, just called by a different name depending on how they are used. I believe I have a spinaker pole on my Capri, but for all I know, it's a whisker pole. It's got clips at both ends and wires running along it and in it. It's made by forespar, but no numbers on it so I can't even look it up on their site. Now that you've stopped laughing, can someone answer the question?
I had a similar question... never used or seen a whisker pole in my laser II dinghy! Searching the web I found this... The same site has info on spinaker poles.
It seems that the strength of a spinny pole has to be greater than a whisker pole for the same vessel as the forces on the spinny pole are much greater.
The article also has good info on caring for the different types of whisker poles.
You have a spinnaker pole. Clips at both ends, wires to the clips and a bridle that is used to hold the pole up with the topping lift and swing the pole forward/aft with the spinnaker guy. And, it's a fixed length.
A whisker pole is often adjustable (mine adjusts from 8' to 14'. The whisker pole typically does not have a bridle. And, simply attaches to the mast and to the jibsails clew.
If you have a pole that has two wires attached opposite each other in such a manner that you could hold one of the wires and balance the pole while the other hangs below, then those are bridles and you have a spinnacker pole. There may be other wires attached to the ends to activate the clips.
Not all Spinnaker poles have two bridles and some whisker poles do have bridles so this might not be a good way to tell
The easiest way to tell Spin pole for our boat is going to be about the diameter of a soda can and is fixed in length. Roughly 2 to 2.5 inches A whisker pole is usually adjustable and has a smaller diameter. For the 25 and 250 it will be about the diameter of a can of 35 mil film to about 1.5 inches.
If your pole is off of a Capri - I would put my money on it being a spinaker pole.
If it is a regulation size pole, the length should equal to or less than your J dimension. Probably about 8 to 9 feet in length.
I was saved from your question because the FORESPAR manufacturer's label was still on my whisker pole and I was able to go to their web site to figure out what its function was. While at their website, I also found out I have a tiller extension. I was also able, by brilliant deduction that my other 'whisker pole' is a boat hook but can also be called a collision mitigation device or drivers error stick, it also sends a message to other boaters and dock watchers that a newbie is headed their way.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by At Ease</i> <br />Here is the web site and the two definitions from Marisafe: http://www.marisafe.com/resources/boatdictionary.asp?vmcid=41&vmpid=16
spinnaker pole a spar attached to the lower front of the mast to support a spinnaker away from a sailboat when sailing downwind
whisker pole a light spar which holds the jib out when sailing downwind
Well Frank, I do carry a hockey stick with me at all times... a guy has to be prepared, because you never know when 11 other guys are going to show up and want to play hockey.
My favorite movie line is from an Australian movie....where a fight starts in a bar and the protaganist rolls up his sleeves and wades into the fight saying "Allright, lets play hockey"
