When I have mounted hardware on my boat's deck in the past, I've drilled my holes, put of marine sealant around the hardward, and tightened the bolts. That' it.
Now a friend of mine told me that he drills his holes, digs out a chunk of core with a coathanger, fills the hole with epoxy, and then drills a new hole through the epoxy. That way, there's no core exposed.
Is that the proper way to mount hardware, or is it overkill?
Bruce Baker Falls Church, VA "Yee Ha" 3573 '83SR/SK
<font size="2"> <font face="Comic Sans MS"> Bruce, It’s pretty standard practice in most yards. One tip I got from the guys in the yard that do this a lot is to take an Allen key and grind the bent over end into a sharp point, then you can put it in a drill to dig out some of the core. Then tape the hole from the bottom and fill with epoxy. When you drill the new smaller hole it will effectively have an epoxy bushing to protect the core from moisture. I just did it on a new stanchion and bow roller. Also Ben clued me into taping the area you are going to drill so you don’t splinter the gel coat. </font id="size2"> </font id="Comic Sans MS">
I think a lot depends on where you sail. My dealer has never done anything but drill squeeze and tighten and I have never heard of any issues from the hundreds of boats he has commissioned. I do the quick and easy as well and have never had any issues on my four boats. HOWEVER! In Kansas we have baking heat for an entire summer and we cover our boats all winter.
Bruce, That's how Don Casey describes it. It all depends on the shape of the core. If it was in good shape you probably wouldn't be resetting hardware anyway. http://www.boatus.com/boattech/casey/39.htm
Hi Bruce, I didn't grind out any core material when I mounted my bow roller. I simply drilled the holes with an oversized drill bit, filled with epoxy, and then tapped the smaller drill holes through the epoxy to hopefully seal the wood core. I like the idea of the allan wrench though.
