 Anchor roller
Capt. Kurt
Initially Posted - 06/17/2005 :  13:25:48  Show Profile
I find it difficult to pull up the anchor while keeping it from scratching the rubrail. It would be alot easier with an anchor roller, has anyone thought of a way to install one? With the foredeck design of the C250 its not going to be easy.
Maybe something like this? (C22 from Cat Direct)
Kurt
#818 C250WK 'Tortuga'
Edited by - Capt. Kurt on 06/17/2005 13:34:56
Response Posted - 06/17/2005 :  14:23:47  Show Profile
Kurt,
It appears that the design illustrated mounts under the stem head fitting. That concept should work, either the c22 mount if the stem fittings are similar or one to fit the stem fitting on the c250.
Northlander
Response Posted - 06/18/2005 :  04:03:57  Show Profile
I installed this one starboard of the stem fitting.
Bay Tripper
Response Posted - 06/18/2005 :  07:28:20  Show Profile
Necia,
Where did you get the fitting? Do you have the unit number for the fitting?
