Absolutely! In fact, the primer wash is supposed to be put on IMMEDIATELY after grinding, blasting, etc, following a washdown with alcohol/acetone or mfgr stuff, otherwise the new oxidation starts instantly. "When product fails, read can" Ron srsk Orion sw fl
You need more than primer followed by bottom paint.
If you are going to keep the boat, do a full-on below the waterline rust preventative treatment. West Marine offers some... and I think there's some good advice on-line at their catalog site. Also see the Interlux paint site for info.
Another alternative is to do the above marine below the waterline paint job followed by encapsulating the keel in epoxy. That will last quite a while. If done well, the life of the boat.
If you've come this far with it, I'd go all the way.
At my boatyard, our resident sailboat repair guru has found that Interprotect 2000, which is a barrier coat, works the best on these keel for a _FRESHWATER_ lake. No, that isn't what it's designed for but he swears he has found nothing that works or lasts over the years. YMMV.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by existentialsailor</i> <br />At my boatyard, our resident sailboat repair guru has found that Interprotect 2000, which is a barrier coat, works the best on these keel for a _FRESHWATER_ lake. No, that isn't what it's designed for but he swears he has found nothing that works or lasts over the years. YMMV. <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
He is correct. I used it on my keel several years ago and only needed a little touchup in a few areas that were scratched or bumped by the lake bottom. One caution though - if you fill in areas that were rusted, to smooth out the keel before applying a barrier coat, make sure it is a waterproof substance. Bondo and many automotive bodyfillers are able to absorb moisture.
