 solar panels
mashedcat
Initially Posted - 06/23/2005 :  15:17:04  Show Profile
how will i wire two solar panels into my charging system?
dave
Response Posted - 06/23/2005 :  15:36:40  Show Profile  Visit Leon Sisson's Homepage
That depends somewhat on the details of your electrical system. A short answer would be: wire them in parallel. A related issue is how many voltage regulators to use, and where to wire them in.
JimB517
Response Posted - 06/24/2005 :  17:30:02  Show Profile  Visit JimB517's Homepage
United Solar Flex-11 panels come with cigarette lighter adaptors. If your 12 volt socket is correctly wired and you are just using the panel part time, you can just plug it in.
I wired 2 panels in parallel and use a simple voltage regulator. Mine plug into a socket I installed above the galley and wires are run to my main electical switch and master ground.
My little home made panel has a socket for the solar panels, a voltage meter, and a 3 way switch for charging batteries (solar, shore power, or engine). Made with plywood and a couple of Radio SHack parts for about $10.
Since my panels are flexible I can tie them to the boom, throw them on deck, or lay them on the cockpit seats.
United Solar Flex-11s are tough and waterproof. You can even walk on them.
Gloss
Response Posted - 06/25/2005 :  07:48:12  Show Profile
I use, and highly recommend, a Morningstar digital charge controller. It permits three phase charging of your batteries. It also has a digital readout which will tell you the amps your panels are giving you, the amps your system is drawing, and the voltage of your batteries.
Very nice
