 Installing Polycarb Windows.
Happy D
Initially Posted - 06/25/2005 :  09:22:52  Show Profile
Greetings Everyone.
I am in the process of refurbing my C25.
I have replaced the core in the coach sides. The window openings edges are filled with epoxy and will be trimmed square. I plan on installing Polycarbonate sheet on the outside of the opening for windows. I am not going to install a interior frame. The window openings edge, will be square, smooth and painted white.
I am trying to figure out the best way to fasten the polycarb to the coach sides. I have two ideas.
The first idea is to drill and countersink the polycarb to accept a flat head machine screw. I am thinking about using a [url="http://sri-supplies.com/images/Round-Base-Weld-Nut.gif"]weld nut[/url] on the inside of the fiberglass as shown in this drawing. I am not crazy about countersinking the polycarb. It seems like it would weaken it. The weld nut would be painted white but visible.
The second idea would be to put the weld nut on the outside and the countersink for the screw in the fiberglass. As shown. The weld nut would be painted black.
Any ideas or suggestions?
Thanks Everyone,
Dan
1977 SK/SR Dinette Hull #29
1979 ChrisCraft 251
1965 Chris Craft Cutalss
eric.werkowitz
Response Posted - 06/25/2005 :  09:58:24  Show Profile
Dan,
My neighbor did a very similar repair to his 40 ft Junneau last year. He used the weld nuts inside and, I believe, a bolt with a gasket on the outside w/o countersinking the Lexan. More importantly, he used a sticky gasket material between the Lexan and the hull. I recall this stuff was expensive, and I believe used in RVs as windo seals. His repair has held up well including a broadside from Hurricane Ivan last year.
Edited by - eric.werkowitz on 06/25/2005 10:02:27
existentialsailor
Response Posted - 06/25/2005 :  09:59:49  Show Profile
I wouldn't countersink the polycarb either. I would use flat head screws mated with countersunk washers on the outside. Another thought, when you drill the holes in the polycarb, make sure you avoid putting them in line with your standing rigging or you may have trouble drilling a straight hole in the fiberglass, assuming you are using the polycarb as the template. That's the only complaint I have about the Crusing Concepts kit I bought for Swimmer, two of the mounting holes were in line with the standing rigging.
atgep
Response Posted - 06/25/2005 :  10:13:21  Show Profile
Looks like a great plan. I suggest you use pan head screws on the outside without coutersinking. I would float the window on the fiberglass with about a 1/32 of lifecaulk or 5200. It will create quite a bond and the screws will be there to "help" that is the way mine is on my 88. I think you will me happy with the plan to use weld nuts. Just make sure they are well caulked to prevent them from vibrating loose.
ronrryan
Response Posted - 06/25/2005 :  11:33:52  Show Profile
Based on some previous experience and reading, my understanding is that (1) holes in ploycarbonate should NOT be countersunk (2) SHOULD be drilled slightly oversize of fasteners, to allow for differential expansion, otherwise cracking is SURE to occur (3) SHOULD be fastened with pan head or other flat faced fasteners outside, preferably with washers, and not cranked down at high torque values. Sounds to me like the flat part on the outside is the way to go, and I gues there's no problem countersinking the inside core layup, particularly if you have reinforced it. Good luck, ron srsk Orion SW FL
Doug
Response Posted - 06/25/2005 :  13:12:14  Show Profile
My standard warning: Be very sure about what you're mounting with 5200. I don't know how many years it will take for the polycarboante to fog, craze, or crack enough to require replacement, but I'm fairly confident that it's not as long as 5200 will remain firmly and solidly bonded to the boat.
