 Tree Sap removal
Initially Posted - 06/27/2005 :  08:08:11  Show Profile  Visit britinusa's Homepage
We were parked under some trees during derigging (won't park there again) and we got some tree sap on the top deck and sail. Any ideas for getting it off. We washed down with detergent last night but hardly notice the difference.
Joint Decision. (Sold)
PO C250WB 2005 Sail # 841.
Moved up to C34 Eximius
Updated August 2015
frankr
Response Posted - 06/27/2005 :  12:16:41  Show Profile
Might try hot water and soap with a small brush - you need to soften the sap. On the boat a cleaner or wax should take it off.
Edited by - frankr on 06/28/2005 10:23:39
JohnMD
Response Posted - 06/27/2005 :  13:22:23  Show Profile
Goof off, Softscrub with bleach, Comet, Bartenders Friend (yes, that's a real product), I've used them all.
Auburn80
Response Posted - 06/27/2005 :  18:08:10  Show Profile
Don't do anything that would scratch your new gelcoat. My vote is for hot water and soap first followed by a mild cleaner/wax if the soap/water doesn't work. Might also try a bug&tar remover after testing on a not-so-obvious place. Any chemical will probably require a thorough cleanup and wax.
As for the sail; I don't know.
Sap can be a real PITA.
Edited by - Auburn80 on 06/27/2005 18:10:28
Bubba
Response Posted - 06/27/2005 :  21:33:34  Show Profile
I use Ronson lighter fluid. It works great. It's cheap and comes with a squirt cap. As with any solvent cleaner you should test it on a small inconspicuous spot. After you've removed the sap, wash with a little detergent and water to remove any residue.
coldducks
Response Posted - 06/28/2005 :  22:12:48  Show Profile
try GOO GONE. a little bottle that works miracles. it takes EVERYTHING STICKY OFF. find it at any home depot.
Edited by - coldducks on 06/28/2005 22:22:19
