 CG of C25 SR mast
Chemist
Initially Posted - 06/27/2005 :  14:46:35  Show Profile
Does anyone know whether the center of gravity of a C25 SR mast is above or below the spreaders? If it is below, my task of mast raising is simplified. I should know, but I haven't really been concerned before now (new equipment for raising the mast is available).
Bob Imes
C25 #1544 sk, sr, "Prime Time", still on the hard
Response Posted - 06/27/2005 :  16:18:35  Show Profile  Visit Leon Sisson's Homepage
The CG of either C-25 mast is pretty much right at the spreaders, give or take just a few inches. Spreader bases are exactly mid-extrusion. Everything inside the mast weighs the same per foot above or below spreaders. The masthead fitting, antenna, anchor light, etc. are about offset by lower shrouds, lines coiled up at the base, etc. This is why using a loop of line slid up the mast to the spreader bases of a simple single spreader rig works so well when using a mast stepping crane.
Dave Laux
Response Posted - 06/27/2005 :  22:32:06  Show Profile
The CG is somewhat dependent on whether the lower ends of the shrouds are stopped off to the bottom of the mast. I would maintain a good grip on the mast bottom in any case. Dave
stampeder
Response Posted - 06/27/2005 :  22:46:43  Show Profile
First time I raised my mast, I used a dock crane, with a loose loop under the spreaders, we raised the mast and found it quite easy to maneuver the base into the step.
I've raised and lowered the mast about half a dozen times in the past year - the biggest and most important aspect has always been keeping the lines and rigging free of tangles and snags.
lcharlot
Antigua and Barbuda
Response Posted - 06/30/2005 :  23:40:27  Show Profile
<br />The CG of either C-25 mast is pretty much right at the spreaders,
The above statement is only true if your boat <u>does not</u> have roller furling. If you add a Crusing Design FF4 furler, the weight of the luff extrusion will move the balance point several inches above the spreaders - I know this from personal experience. This can give you a nasty surprise when doing a mast raising evolution, in that a mast that should be perfectly balanced on the mast crutch will, because of the furler, be top heavy, casuing the butt of the mast to suddenly jump up and try to whack you in the face when you pull the pin out of the tabernackle. This problem is especially severe in Tall Rigs, as the "nominal C.G." at the spreaders is about 12" aft of the transom when the mast is down, due to he Tall Rig being 30' instead of 28'. With the Tall Rig, it is pretty much a necessesity to build a special mast crutch that hangs off of the transom, far enough to catch the mast above the spreaders, instead of sitting on the cockpit floor.
