My 2001 Honda 8hp 4 stroke XL shaft is about 4years old now.(bought it new, although a couple yrs older model) I think it might be time to change out the impeller. Is this possible while mounted on the boat? Anyone know the procedure? Or, any reason to think it is time?
Last one I changed out was after 15+ years of service... which might have been stretching it a wee bit. But your mileage may vary... reckon it depends a bit on how many hours your put on your engine. Typically, I might put 5 hours a year on mine.
I know that impeller life is radically shortened if you run it dry, either from ventilation or a clog on the water intake ports.
You have to pull off the lower end of the motor to change the impeller. Unless your boat is out of the water you would have to pull the engine. I recommend you buy the Honda manual for your engine before you begin. I believe it cost about $35.00 but Honda parts are not cheap and that may be the best $35 you spend. Why do you think the impeller may need changing?
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by JimB517</i> <br />pulling the lower end means you are also going to be dumping the lower end oil, you don't want that in the water! <hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
You DON'T have to drain the lower unit gear oil just to change the impeller. The lower unit unbolts from the shaft housing in one piece (you do have to un-pin the gear shift rod up in the powerhead). Unbolting the lower unit to change the water pump impeller does not require you to drain any oil from either the engine or the gear case. If your boat is in the water, it could be done sitting in a dinghy if the water is calm. However, I would remove the motor from the boat and do the job on land if possible, with the motor on a workstand. Trying to do even a simple job like replacing a prop and shear pin is a lot easier on shore than trying to do it sitting in a dinghy (been there done that), and there's less chance you will lose some small but critical part like the snap ring that attaches the gear shift rod to the shift lever. Be very careful removing the 4 lower unit bolts, especially if you keep the boat in a salt water marina. The bolt threads in the aluminum may be clogged with salt and you will strip them if you apply too much wrench force. If you can't break them loose with 15 foot pounds of torque, try soaking the threads with Liquid Wrench overnight. Whatever you do, don't use heavy force; if you strip the threads, you'll regret it.
