 Swing Keel Winch Life?
GeorgeB
Initially Posted - 07/27/2005 :  13:00:23  Show Profile
I know that the isssues of Swingers have been discussed up and down on this forum a lot over the years, but I don't remember a discussion of this question. Is there a recommended life expectancy for the Keel winch?
George Barton
Abegweit
1980 SK/TR #1872
Response Posted - 07/27/2005 :  13:30:34  Show Profile  Visit Leon Sisson's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote">Is there a recommended life expectancy for the Keel winch?<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">I replace my swing keel winch when the winch drum gets so rusty that I worry that it might not continue to be reliable until the next anticipated haulout. For me, that comes out to replacing the winch about every two to four years. I replace the swing keel cable and bolts every two years no matter how good they look. Of course it depends on how fast your parts deteriorate in your environment.
GeorgeB
Response Posted - 07/27/2005 :  19:36:09  Show Profile
Leon,
Thanks for the reply. Sounds like you replace much more frequently than I have. I'm still on the origional winch. It is sturdy and rust free. However ..."sticth in time saves Nine" and all that. It is the only component I didn't replace in the keel system.
Response Posted - 07/27/2005 :  20:37:27  Show Profile
I'm reasonably confident that WOTAM still has the original winch... after 28 years.
I removed, dismantled, inspected, cleaned, painted and re-lubed the winch a couple years ago.
The only part on the winch that is 'fragile' looking at all is a pawl and spring that keeps what I'll call the "the secondary shaft" from rotating backwards... (this is what causes the brake to engage).
Will probably repeat the overhaul when I put a new keel cable in this fall (replacing that every 2 years).
jlguthri
Response Posted - 07/29/2005 :  21:19:04  Show Profile  Visit jlguthri's Homepage
This is what broke on mine..
Response Posted - 07/29/2005 :  23:59:52  Show Profile
&gt;"This is what broke on mine.." [the pawl]
I'll be sure to take an extra close look at it on the next overhaul.. As I mentioned in the previous post, it was the one part of the winch I thought they shoulda made beefier.
