Question for the group. The shape of our sails under sail seems to curl and twist.It looks like the top off the sail is not capturing the wind at all. This is true for both of our sails. Our main is original, 1983 (yes I know it's old) Genoa is 4 years old, but was cut from 150% to 140% (not sure if the cut was right). Any advice is much appreciated.
Cate, Sounds like my sails, which are original also. I think they're old stretched sails. I'm good with it for now as I don't race but will replace or re-cut both main and head sails in the next couple of years.
It would be difficult to answer your question without seeing your setup and sail trim on the water.
Do you have telltales on both your headsail and main? <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">
Yes I have telltales. I'm not sure it's a trimming problem because no matter what tack I am on, the sails still seem to spill off air at the top and then curl around at the bottom. I will try to take pictures of our set up under sail...or I'll see if I can get and answer from other sailors at my marina.
twist on the main can be a good thing - to depower in heavy air or to power up a little off the wind.
When pointing or heading up, it is not so good (a little, OK).
The top batten of the sail should be parallel with the boom, not twisted way off. To flatten the sail :
(1) maybe your boom is too high. Lower it, and tighten the halyard more than you are doing. You probably don't have a cunningham, but you can tighten that. Most likely you are not using enough halyard tension.
(2) pull the main sheet in tight.
(3) tighten outhaul
(4) tighten vang (not usually needed upwind).
(5) Mast may be raked too far aft.
To flatten the upper part of the jib:
(1) move cars forward a little, and sheet in hard.
(2) increase tension on jib halyard.
My old 155 jib no matter what I do it is loose around the spreaders - its a little blown out. I usually only use it downwind or on a light air day for practice.
Cate, I highly recommend "[url="http://www.dedekam.com/sailtrim.html"]Illustrated Sail & Rig Tuning[/url]" for figuring out what's going on with your sails. The book has great illustrations and a very step by step methodical approach to getting your sails & rigging up to snuff. I struggled with this until a friend showed me a copy of his book. Now things are starting to gel in my head as to why things happen, and what I can do about them. It could simply be that your sails are old & stretched as you suspect, but with this book you'll be able to definitively figure it out.
Some very good advice here as usual. I'm going to try making some adjustments to the genoa cars, halyard tension (main, genoa is on furler), boom vang, boom height, etc. as suggested. Will also look into great book recommendation. Our sail shape is not working when pointing close haul,close to wind. It's been frustrating as I used to be able to come very, very close to upwind with smaller sailboats I learned on. Thank you one and all.
Next year-NEW SAILS!! (Would have had them this year if the darn original rudder hadn't broken off at the tiller-rot,rot,rot. Now have beautiful IdaSailor kick-up.)
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Chris Z</i> <br />Cate, How do you like the kick-up rudder. That is on my list of wants. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> Chris- I absolutely love the IdaSailor kick-up rudder. (about $810 sailboatowners.com) The airfoil design has been a noticeable improvement. Seems like the boat turns on a dime now. The kick-up has also been great for our SK in our shallow bay. We can go many places the fixed keel folks can't. Pulling the rudder up requires a bit of strength, but I just put my foot on the stern and give it couple of good pulls and the whole rudder is out of the water and cleated down. Lowering the rudder requires just a little nudge by hand. The gas struts are nice. Only downside is that the old tiller wouldn't fit so now it has become nautical decor in our hallway. Sentimental value I guess. The new tiller is beautiful mahogany and ash. Very nice wood.
I too have a very old main sail - I believe it is the 1981 original. Last spring I had it re-worked at Northsail. They put three tell tales on the leech. the tell-tales have aided my understanding of optimal sail shape. I put my own tell tales on my crappy jib, and that too, helps.
