That seems like an awful lot of damage in six years. I wonder if treating them with 303 yearly would help? Not sure how it would work on a hard material as opposed to cloth type stuff.
I wonder if you could make a stiff cloth cover you could raise on a pig-sticker type of flagstaff. Raise it up above the crane by pulling the pig-sticker upright, then lower over the top to protect from UV. Getting it around your antenna might be a trick, but if yours is like mine, it's offset from the crane, so it could probably be done.
Mine looked exactly like yours when I dropped the mast last year. I replaced them with the CD sheaves that you linked. Dimensionally, they were a perfect match for the originals.
The ones that CD shipped were actually black (contrary to their pictures), which I think improves their UV stability.
FYI. I noticed that the mast crane sheave pin is a smaller diameter than the masthead fwd sheave pin, I'll have to ream out the crane sheave pin hole to take the original pin rather than use the skinny new pin that came with the crane.
I don't think the white acetyl plastic has much, if any UV protection or stability. I haven't researched it, I'm extrapolating from the condition of the black (not acetyl) sheaves in my Harkin blocks compared to some others on Pearl.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Dave5041</i> <br />I don't think the white acetyl plastic has much, if any UV protection or stability. I haven't researched it, I'm extrapolating from the condition of the black (not acetyl) sheaves in my Harkin blocks compared to some others on Pearl.<hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">From what I learned about plastic plumbing on docks, carbon is added to the plastic, which blocks UV from penetrating deeply enough to damage the material. Ordinary PEX pipes quickly become toast.
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Tradewind</i> <br />Looks like the bearing on my CDI furler. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote"> This is puzzling to me, since the plastic block inside the furler drum gets absolutely no UV exposure. Mine is 12 years old and looked pristine when I checked it last April.
At the risk of hijacking the thread, I'd be curious to hear anyone's experience with CDI's ball bearing upgrade for their FF4. My wife complains that our current FF4 (without the ball bearing upgrade) is hard to pull out/in, but I think most of the resistance is the sail and wind, which the bearings won't help. Does the ball bearing make a noticeable difference?
I guess this is a relevant question to this thread, since if Steve's block is deteriorated severely he may want to consider the ball bearing upgrade instead of a direct replacement.
Rick, I have always had the B/B option so I cannot comment on the difference but your observation regarding the wind and sail is spot on as evidenced by the ease of rolling in the furler as the exposed sail surface is reduced. If it is hard to furl when the sail area is reduced I would check the furling line alignment with the fairleads from the cockpit to the furler and flush the B/B's with fresh water (per the manual). Paul, When I replaced my masthead sheaves (from CD)on my C25 they were black anodized aluminum. Would those work on a C250?
