Has anyone been faced with the task of removing an old name from boat which PO had painted on? If so how did you do it? I have been searching the net for possible solutions. Seems on bottom paint most just sand it off since it will be painted over again. Their is also paint remover made for fiberglass but I have not been able to determine if it can be used on gelcoat above the water line or if its main use is for removing bottom paint.
I've heard that Easy Off oven cleaner works. I believe that you spray it on then cover it with plastic wrap. Let it sit for a day then clean it off. Follow this up with rubbing compound and wax. I haven't tried it though. I suppose it also depends on the paint that was used. Epoxy or regular automotive lettering paint.
I'd be very careful about products like that--I'd stick with a fiberglass-safe paint remover, which is formulated specifically not to harm gelcoat. WM has one you can buy in a spray bottle for $14 or a quart for $20.
Also, be aware that when you apply a name, whether by painting it or by applying a decal, the gelcoat all around it chalks and erodes naturally, but the gelcoat under the name is protected, and does not. Thus, after you remove the painted name, you're likely to notice a slight shadow of the old name. After a couple years of chalking and polishing and waxing, the shadow will fade. You could probably sand it and rub it out, but personally, I don't think it matters that much. Most people who aren't aware of it won't even notice it. I changed the name of my boat, and after a couple years, I can hardly see a hint of the old name.
. . . by applying a decal, the gelcoat all around it chalks and erodes naturally, but the gelcoat under the name is protected, and does not . . . Most people who aren't aware of it won't even notice it . . .
Exactly, we discovered an old name on the transom of our boat, but only after I compounded, polished, glazed and waxed . . . and the sun was at just the right angle.
