As I mentioned in a another post I haven't been down to my boat but once in several months and she was pretty green.
I have access to a pressure washer and planned on giving her a good cleaning this weekend if time permits.
Besides being careful where and how close I point the tip (I'll be using a fan tip) and making sure not to get up under handrails, ports, etc... any tips/pointers on what to and what not to do?
Gary, Like you said don't get close to bedded items.You do not want to blow out any caulk and create leaks. You will get the hang of it really fast. Give a man a pressure washer and he's entertained all day!
Stay away from all of the teak, too. Pressure-washing won't just remove any finish, it can instantly dig out the soft parts of the grain. The teak might look new, but it won't be smooth.
Yep, literally just finished 7 hours of pressure washing the driveway and sidewalks at home!
When pressure washing, be careful around the knot meter. The pressure wash will clear it of any debris clogging the knot meter but if the spray is held to close to it or a very strong spray, the knot meter inside works can crack off. That is what happened to me last time I had the yard pressure wash the bottom. Luckily, the sealing/seating housing is intact - No leaks. I have the replacement transducer ready to install whenever I get around to it.
FWIW, I would not pressure wash the delicate topside gelcoat on a boat. I wouldn't pressure wash a car either. 3000 psi gets less dirt off a car finish than a simple wipe of a sponge. Similarly, a nice soapy brush on the end of a broomstick or aluminum telescoping handle will do just as good a job on topside fiberglass as a pressure washer, with much less risk of damage.
Pressure washing is good for very rough surfaces that present severe resistance to a scrub brush (sidewalks, driveway, stucco walls), or areas that are ergonomically difficult to reach (boat bottom, high-up windows and walls). But the deck of a boat does not meet either of these criteria.
I agree with everything you're saying although the pressure washer I was going to use can be adjusted down to 1200 - 1600 psi. I decided not to use it anyway. To much PITA to lug it down to the boat and then worry about whether it would get stolen overnight.
Also, by the time I unloaded it, got it setup, and started washing I could have been half done using the brush. Plus I didn't want to worry about damaging the teak or blowing water where it wasn't supposed to be.
I'm planning on going down tomorrow and using my boat brush, soap, and elbow grease to clean it up. What kind of boat wash did we decide was the best to use on the hull? I use the Starbright deck cleaner with PTEF for the deck.
Well, the green monster is no more! About 4 hours of scrubbing in the hot Texas sun and she almost looks respectable again. Unfortunately I ran out of steam before I got the cockpit and cabin top clean. It was sooo hot (and extremely humid) by 9 am I had to keep soaking myself with the hose to keep from passing out.
It's the worst the boats ever been since I bought her and I feel really guilty letting her get in that condition. Once it cools off in the fall I'll pull her and scrub her down with the Poli-Ox and put on 4 or 5 coats of Poli-Glo. I would think she would be a lot easier to keep clean after the Poli-Glo.
...I would think she would be a lot easier to keep clean after the Poli-Glo.
...on the deck and cabintop? Some here have advised against that. I prefer the PTFE/PTEF cleaners for decks and cockpit.
Do some research to verify this, but IIRC Practical Sailor raved about the use of NuFinish (inexpensive non-buffing automotive "polish") for non-skid and other horizontal surfaces. I even went out and bought some, but never got around to trying it. I should put it on my list to try on the new boat.
Not sure how you deducted that from my post but no, I'm not planning on putting Poli-Glo on the decks. :)
As you stated, many have recommended not doing that and you guys are far more experienced at this than I am so I generally listen to others mistakes so I don't have to undo mistakes and therefore have more time to sail. :):).
Edit: I guess from my comment about cleaning the decks and cabin top. Sorry for the confusion.
I have used the Starbright Deck cleaner with PTFE and it does work great. In fact, I picked up another bottle of it last Saturday. Just didn't get to use it.
New question, could I use Poli-Glo on the side of the cabin top?
I've used it in the past and it worked good but I don't remember using it on non-skid. Seemed like I used it on the hull to shine it up. I just don't remember for sure.
Hmmmm... Poli glow on the side of the cabin? Good question! I've considered doing that several times. Since the hull comes out so well and the side of the cabin tops is pretty dull, you could certainly do that. I'd advise that if you do it, start with Poli-prep then rinse-rinse-rinse then bleach and TSP, then maybe the ketchup treatment, rinse .... You know the drill - as clean as possible. The key about applying Poli-glow is keeping it where you want it, preventing drips and keeping it from pooling up on the nonskid surfaces on the gunwales. That's my only advice.
