After a few attempts at the seized macerator, it is working perfectly; however, there was an unpleasant order that took some chasing and became obvious with colored liquid (RV pink).
I hopped on Jabsco's site and watched some YouTube University films but they seem to focus on the pump mechanism where I believe this leak is either where the base mounts to the floor (if that is even fluid-bearing) or there is an issue with a seal on what appears to be a cleanout or inspection cap...or it's cracked. I am actually glad this issue came to light because the pump has always been less effective than I thought it should have been and sounds like it cavitates.
Anyone experience this or know if it is worth breaking the potentially-good seal on to investigate? Hoping to hear it's an O-ring for 75 cents.
It could be a cracked base, cracked bowl, the gasket between the two or the clean out cap. Or something I haven't thought of. I'd start with clean-cap as the most likely, least disruptive attempt at repair. If you pump out most of the fluid, the level should be below the seam between the bowl and base.
1988 C25 Wing Keel Std Rig Tohatsu 9.9 Tiller Steering and 2003 C250 Wing Keel Std Rig Inboard Diesel Wheel Steering
Thanks. It did not dawn on me, until I wrote and was looking at pictures to job the memory, that this was a cleanout (not really sure what else it would be) but I'll give that a shot.
