 leaking Scupper
Initially Posted - 02/17/2018 :  21:28:23  Show Profile
I am finally tired of water running off the shelf and soaking the quarter-berth with every rain. After verifying that the starboard scupper was the source,I cut the brass tube in half to remove it, and it fell out! There was no bedding! The tube was simply inserted and flared to a compression joint. I'm not surprised that it failed sometime in the past. i'm letting it dry out while the weather is nice before putting the new ones in.
Dave B. aboard Pearl
1982 TR/SK/Trad. #3399
Lake Erie/Florida Panhandle
Response Posted - 02/18/2018 :  04:59:05  Show Profile
Isn't it great to find the source of a long standing problem and fix it! Every time you think about it you break into a satisfied smile!
Response Posted - 02/18/2018 :  10:21:09  Show Profile
Good opportunity to GO BIG!
Response Posted - 02/18/2018 :  14:08:00  Show Profile
Originally posted by bjoye
...Raw epoxy can not be exposed to UV or it will break down. So I'm ordering some 1.4"x3" tubes and the flanging tool from Amazon. I will apply one more thin layer of thickened epoxy to narrow the diameter just a little, then crimp into the hole the Moeller tube... The brass tube will protect the epoxy.
How about just smearing some of this stuff inside the hole. If the epoxy is fully cured, scuffed a little, and the amine blush is washed off (water soluble), it should bond just fine.
Edited by - Stinkpotter on 02/18/2018 14:14:43
jduck00
Response Posted - 02/19/2018 :  20:53:34  Show Profile
I've thought about adding scuppers to mine for a while now. Not exactly sure on how I want to do it other than I do. My line of thinking so far is to add some decent size through hulls and fiber glassing the floor up to them. Will probably be on my summer to do list while I can't sail. I've got the drains that go down through the boat to the bottom. They seem to always be stopped up with a little something making a mess out of the cockpit.
Also thought about sloping the cockpit floor at the same time so it will drain with the keel down. I would rather leave the keel down at dock, but can't because the cockpit won't drain.
Jeremy Duck
The Lucky Duck
1980 SKSR Hull # 1850
Response Posted - 02/20/2018 :  20:41:46  Show Profile
I am going with two part poly scuppers than can be easily replaced. I talked to a stinkpotter who has the same brand and is replacing them with the same ones after 12 years of Florida sun. That is certainly long enough for me. I intend to bed them with this new Sticky silicone adhesive caulk. Its fairly expensive, but comes highly recommended. It doesn't hurt that my daughter got me a multipack for Christmas because she thought it could be useful on a boat. Smart girl! Incidentally, mine is 1 5/8" diameter and I also cut it in half with a Dremel, easily removed the two halves, and put them back in with epoxy putty filling the cut while I await delivery of the new ones since Pearl is in the water. The marelon ones I bought would have required enlarging the holes and still had 1 5/8" ID.
Edited by - Dave5041 on 02/20/2018 20:53:42
Erik Cornelison
Response Posted - 02/23/2018 :  07:17:47  Show Profile
What size are those BIG Scuppers? That's my next install.
Erik Cornelison
1986 Standard Rig SW. #5234
Response Posted - 02/23/2018 :  08:51:55  Show Profile
Don't know how big but the boat,a Capri 25 was fitted for the 2014? Trans Pac ocean race from California to Hawaii single handed. Stuart (Doug) Paine and his boat Jack.
Response Posted - 02/23/2018 :  20:37:41  Show Profile
Wichita was a hot bed of Snipe sailing back in the day. Google Snipe Transom and you will see some scupper to transom ratios that are amazing.
Response Posted - 02/27/2018 :  22:56:49  Show Profile
The temporary repair and reinstall of the original scupper with bedding has cured the leak. A Florida deluge tested it. It was totally dry this morning, so yes, Steve, it is a joy.
Response Posted - 02/28/2018 :  05:19:10  Show Profile
Dave, Did you use the plastic slide together or the brass tubes?
Response Posted - 03/01/2018 :  18:32:42  Show Profile
I will be using plastic snap together or threaded. Not having to twist one end has some benefit for bedding. The repaired brass tube will be in place until I pull Pearl at the end of the month and do the prep and install on the hard and dry. Plastic snap together from T-H Marine is what the stinkpotter at the marina replaced after 13 years of Florida sun.
Wnccat25
Response Posted - 03/21/2018 :  18:18:18  Show Profile
. Seams likthe two sectionse will move against each other. Yours will ? Brea.k pvc hreaded together w rubber seals would have been cheaper?
INDIAN, 89 Catalina 25,wing keel,short rig, classic. W-NC
Response Posted - 03/21/2018 :  18:43:52  Show Profile
Anybody consider using regular home center 1-1/2 or 2" PVC pipe glued in with polysulfide? One of my scuppers is suspicious so if I can remove them both and replace them with PVC it might be a decent solution.
Response Posted - 03/22/2018 :  04:19:00  Show Profile
I would love to utilize a PVC pipe but I just haven't come up with a good and decent looking way for making the mushroom heads that would seal the interior and exterior edges without it looking llike a hack job.
dasreboot
Response Posted - 03/22/2018 :  05:00:34  Show Profile  Visit dasreboot's Homepage
I got it! Ill see if i can 3d print slip on mushroom fittings in abs. they can be glued to pvc using ABS to PVC transitional cement. that way i can get those cool large capri25 transpac scuppers.
Todd Lewis
Eowyn 87 TR/WK C25 #5656
ARWEN 84 TR/SK C25 #4031
www.mainsailsailingschool.com
odonnellryanc
Response Posted - 03/22/2018 :  08:24:16  Show Profile
I think I'm just going cut mine out and repair with the rest of the fiberglass work I have to do this spring. Already have plenty of fiberglass, epoxy, paint and primer to do a decent job I think!
Response Posted - 03/22/2018 :  10:23:36  Show Profile
Wow, I never thought of a 3D printer to make the mushroom slip on end pieces. Brilliant! I'll be the first to buy 4 from you.
SKS
Response Posted - 03/24/2018 :  02:21:55  Show Profile
For those using PVC pipe, please be careful.
Unprotected PVC will break down in the sunshine.
Use CPCV (the grey pipe) or plan on painting the PVC pipe, or make replacing it a routine maintenance item every few years.
Response Posted - 03/25/2018 :  20:55:03  Show Profile
Any way to make a wet sand or modeling clay cast and mold the ends using thickened epoxy?
Response Posted - 04/03/2018 :  15:28:28  Show Profile
I can't see going to al the trouble of making pvc work when more uv resistant plastic scuppers are not expensive.
Edited by - Dave5041 on 04/03/2018 15:29:30
