I have a 1986 c25 (standard rig) with internal halyards. The plastic sheeves (turning blocks ?) at the base of the mast are breaking apart (where the halyard exits the mast). I guess they're original, but I don't know.
The prior owner replaced the halyards with a too-large size that doesn't fit the sheeve, which only makes the problem worse, so I must replace the sheeve or turning block at the base of the mast. (Obviously I will also replace the halyards with the properr size line).
My problem is that the screws don't want to turn. I guess because they're stainless and the mast is aluminum.
I have sprayed WD40 on the screw heads, and inside the mast (hoping it might drip down to the screws and help them come loose).
What better way is there? Do I need to get an impact driver? Thanks
Cap...you might get away with just inserting the screw driver and tapping the end of it while turning. Worked for me when I decided to remove all the hardware on the boom. An impact gun might be overkill, keep it in mind should all else fail. I have the impact gun but also an impact screw driver that gets its power from a hammer. Didn't need either of them.
Sometimes it helps to turn clockwise before trying to remove the screw ... breaks the seize sort of.
Good luck and let us know what works for you.
Val on Calista # 3936
OH and remember to coat any screws being replaced with anti-seize compound...comes in a tiny squeeze tube of bronze powder in a binder.
A little heat and a soak with PB-Blaster might help things along.
I have removed/replaced all my mast and boom fittings. Where I needed/could, I just grabbed the screw head with a vice-grips. I had quite a number of the screws break off (or if they were flat heads) I ended up drilling them out (this went very quickly).
Be sure to use 'never seize' or an appropriate grade of Loctite when replacing the screws to avoid problems the next time they have to come out.
I love PB Blaster. Home Depot used to carry it but now all they have is about a hundred cans of WD-40. And I do keep a can aboard. I prefer using the non-presurized can with a pump spray. And no-seize is a must when using two different metals where electrolysis can be a problem, which it is around salt water where dock power may be bleeding into the area.
