 4 stroke motor mounts
cdreamonly
Initially Posted - 11/02/2005 :  21:28:49  Show Profile
I have been looking to replace my outboard motor mount and have noticed that a lot of catalogs specify "not for 4 stroke outboard motors" A 4 stroke will weigh more per hp than a 2 stroke motor, but as long as the it does not exceed the mount weight rating it should be OK right?....or is there something else about 4 stroke motors that you have to worry about?
83 tall rig w/k
Response Posted - 11/02/2005 :  22:24:51  Show Profile  Visit Frank Hopper's Homepage
I recently changed to a 4 stroke and the difference in thrust was amazing. It makes my new 4 spring super 4 stroke mount jump like crazy when I change gears at anything less than the lowest RPM. I can imagine some mounts not being able to handle the thrust issues.
Douglas
Response Posted - 11/02/2005 :  22:46:18  Show Profile  Visit Douglas's Homepage
Yea its called liability
Response Posted - 11/03/2005 :  19:05:25  Show Profile
Garhauer makes three different versions of their outboard motor mount. Structurally, the mounts are identical with the only difference being the number of springs on the mount (2, 3, or 4) which assist in lifting.
I've only seen pictures of their recent mounts, and aside from the number of springs, it looks to be identical to my original Garhauer motor mount.
Edited by - dlucier on 11/03/2005 19:15:52
cdreamonly
Response Posted - 11/03/2005 :  22:46:35  Show Profile
Thanks for the replies....Higher thrust....is that caused by lower RPMs, and a change in prop pitch over what is typically used on 2 strokes? 4 stroke motors typically have better low rpm torque so I would imagine that with a 4 stroke you might want a "stiffer" mount to be able to handle the torque and not fatigue. You can tell that my boat is out of the water for the winter and I have plenty of time to contemplate things like this......
Are the mounts from Catalina Direct Garhauer?
Response Posted - 11/04/2005 :  11:04:54  Show Profile  Visit Frank Hopper's Homepage
<br />Garhauer makes three different versions of their outboard motor mount. Structurally, the mounts are identical with the only difference being the number of springs on the mount (2, 3, or 4) which assist in lifting.
The 4 spring does have longer braces that mount against the transom.
Response Posted - 11/04/2005 :  13:14:54  Show Profile
<br />
Is that the only change they made to make it a 4 stroke mount?
<br />I recently changed to a 4 stroke and the difference in thrust was amazing. It makes my new 4 spring super 4 stroke mount jump like crazy when I change gears at anything less than the lowest RPM.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
The one thing about the Garhauer mount is the few inches of up and down travel that exists when it is in the lowered position. This inherent travel results in the mount dancing when in reverse, although mostly when using higher rpms.
Response Posted - 11/04/2005 :  21:15:17  Show Profile  Visit Frank Hopper's Homepage
I believe it is the only difference. I think all the models have the wider 4 stroke mount board.
Gene DeMambro
Response Posted - 11/06/2005 :  12:29:22  Show Profile
On a somehwta related note, the piece of wood where the motor attached to the motor mount on my boat needs repalcing. Any ideas on what to replace it with?
Gene
rclift
Response Posted - 11/06/2005 :  18:55:09  Show Profile
Gene,
My Honda 8 xls classic weighs in at 84 pounds so I elected to keep the old mount and upgrade with the new board and stainless steel backing plate. This has worked fine for the last 4 years. Each piece was $39. from Catalina direct.
Edited by - rclift on 11/06/2005 18:58:42
Response Posted - 11/06/2005 :  19:48:57  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Gene DeMambro</i>
<br />On a somewhat related note, the piece of wood where the motor attached to the motor mount on my boat needs repalcing. Any ideas on what to replace it with?
Gene
Gene,
Unless it came this way, the previous owner of my boat replaced the mount pad with a [url="http://www.garelick.com"]Garelick[/url] mount.
tinob
Response Posted - 11/09/2005 :  18:59:51  Show Profile
Don,
Don't see the bolt holes to bolt the motor onto your board. Don't you use them? Or didn't you get to it yet?
Val on the hard DAGNABIT # 3936
Response Posted - 11/09/2005 :  19:43:57  Show Profile  Visit Frank Hopper's Homepage
What bolts are you talking about?
Response Posted - 11/09/2005 :  20:46:28  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by tinob</i>
<br />Don,
Are you talking about a security bolt through the pad and motor mount? If so, no, I don't use them. I use one of those almost useless MasterLock outboard locks.
Edited by - dlucier on 11/09/2005 20:54:44
tinob
Response Posted - 11/10/2005 :  09:26:39  Show Profile
Yes that's what I'm talking about. I'm surprised, but then I noticed that Frank wasn't using them either. I don't use them for security so much as for keeping the motor from flying off. The new four strokes especially have a very shallow purchase on the motor block compared to the depth that the old Johnson 2 stroke had and even that one I through bolted. Better safe than sorry.
Response Posted - 11/10/2005 :  10:39:30  Show Profile  Visit Leon Sisson's Homepage
I agree with Val about bolting the motor to the mounting pad. I'd say it's particularly important for high thrust props (in reverse) and long trips. Over the years, I've heard countless sad tales of outboards sliping off transoms (of small power boats). At the very least, every outboard not bolted directly through the transom (with the possible exception of dinghies) should use some sort of safety leash. Using a bicycle cable and marine grade padlock also serves as a theft deterent.
