 New Roller Furling Jib
lcogge01
Initially Posted - 02/13/2006 :  13:23:03  Show Profile
My 2000 250WK is in a slip and I'm needing to replace my damaged jib (torn and blown-out). Is it possible to connect a temporary forestay, take the CDI roller down and replace while the boat is in the slip?
It seems straight forward enough... I just wanted to run it past the wisdom of this forum before attempting.
Thanks!!
Lon
Lon
Zermatt 2000 250 WK
Chandler's Landing - Rockwall, TX
Tom Potter
Response Posted - 02/13/2006 :  14:22:06  Show Profile
I installed my CDI at the dock with the mast up. I tied the bitter end of the unused jib halyard to the mast cleat, and then ran the other end that hooks to the jib from the top of the mast forward to a bow cleat, pulled it tight and tied it off. From there you can remove and install the CDI furler. Just make sure you have that halyard secured good.
Edited by - Tom Potter on 02/13/2006 14:23:22
RSHOOTER
Response Posted - 02/13/2006 :  19:25:46  Show Profile
I could be reading your thread wrong but if you already have a CDI Furler you don't need to take it down to install a new furling sail.
Keith D.
Response Posted - 02/13/2006 :  20:24:10  Show Profile
I agree, the CDI furler has an internal halyard, all you would need to do is attach a messenger to the end of the halyard so you can pull your new sail up the track once you have pulled your old sail down. Very straightforward.
lcogge01
Response Posted - 02/14/2006 :  12:46:43  Show Profile
Thank you all for your help on this!
Lon
