Should I be able to unloosen the "wing nut" from the depth transducer through hull, push it down to create separation from the exterior hull, juice it up with some 5200 and tighten it back up ?
The knotmeter through hull looks a little different. It appears to have a collar and tube that support the "pinwheel" - I'm going to replace it with the available "blank" and use my GPS to track speed, but I don;t think this will cure the leak - can I unscrew and push the knotmeter unit down a bit and juice it up with some 5200 around the bottom end as well ?
If anyone has done this job, I'd appreciate any pointers. thanks.
It's my understanding that o-rings are also employed to make these units watertight - which you haven't mentioned. Have you talked with the manufacturer? Polysulfide may also be a better choice as it cures with moisture.
I had a huge issue with my knotmeter impeller leaking big time also. It was leaking because of old, worn-out o-rings. I replaced them (had a dickens of a time finding new ones, but I found some at Lowe's), greased it up with silicone grease and it doesn't leak a bit! I don't have a dummy plug for my unit so it was imperative that I get it fixed. It is a Datamarine and I guess they're not even around anymore to get o-rings through them. But, I could tell it was leaking through the 0-rings as that was where the water was pouring in inside the boat. For whatever it's worth....! Good luck!
You'll Be able to remove it, you just won't be able to use the housing again when you do remove it. If the O'rings are rubber or polymer do not use polysulfide as it will eat plastic and rubber. In My opinion, you only want this thing coming out when you muscle it out. Use the 5200.
Hi JM, I re-bed my knot meter through hull last season. It was set in some type of mastik. After I cleaned it all out I used 3M 5200. Here are some photos of what mine looks like. I'm sure that there are different ones out there but maybe they'll help.
This shows the the pick-up and the plug next to the through hull. I use the plug when I have the boat out of the water to protect the paddle wheel on the pick-up.
I'm on top, of the water. As indicated, I believe both of my leaks were in the area 'surrounding' the knotmeter and depth transducer, not through them. I put some 3m 101 around both,(on the inside) and it seems to have minimized the flow - I just get a small puddle in my bilge, nothing even 'pumpable'. I'm keeping some plugs handy just in case, and I'll probably wait until the fall haul-out to remove and re-install. Thanks for looking out for me.
