 There be sheaves here "update"
frich
Initially Posted - 05/17/2002 :  12:44:56  Show Profile  Visit frich's Homepage
I finally installed my new 2" dia. sheaves from the Long Island fabricator, I have these insights for anyone who cares.
I installed the aft sheaves first (the ones where the divider is held in place).
Then I installed my 5/16" halyards, draping them so they extended on both ends of the mast head.
Heres the tricky part, from the top aft part of the mast head i installed the port sheave first and moved it towards the final position. Then placed the pin partially in to hold it.
Moving the starboard halyard aside i then placed the other sheave in from the same aft position. I moved the line around the sheave and working with a screw driver to move the sheave from the foward part of the mast head i aligned the pin hole. I then placed a small peg to hold this from the starboard side, then pushing the metal pin from the port side it pushed out the temporary pin. Finished it w/ a new cotter pin.
Dont forget to oil the pins prior to placement! Job was a bit tricky but they do go in and work, and plenty of clearance for the halyards!!!
Good luck to all that have purchased these.
Frank Rich
84 C25 SK
Bristle
Response Posted - 05/17/2002 :  22:48:24  Show Profile
Thanks, Frank--your find was a great service to many of us! I'm about to install mine, but was thinking of a little white grease inside (to last a little longer than oil). Do you suppose your source would like to be a supplier to Catalina Direct? They need help on this.
Edited by - bristle on 05/17/2002 23:02:26
frich
Response Posted - 05/18/2002 :  00:02:04  Show Profile  Visit frich's Homepage
If its winter work i don think Ed would mind, I should walk through his shop and see what other goodies he has.
[/quote]<img src=icon_smile.gif border=0 align=middle>
