 Removing a Nissan lower unit???
Bubba
Initially Posted - 03/19/2006 :  20:10:18  Show Profile
My 8 hp Nissan 2-stroke seems to have a little water getting into the lower unit gear lube. I suspect the likely culprit is the 9-year-old propeller shaft seal. Unfortunately, the shaft housing is frozen to the lower unit, so I figured it would be easier to work on if I removed the lower unit.
Does anyone know how to remove the lower unit?
I unbolted it and disconnected the shift linkage but it appears there's more to disconnect somewhere. Any advice would be appreciated. (I have a Clymer Nissan/Tohatsu manual on order, but with only a couple of weeks to splash I'm anxious to finish this.)
Dave & Deb
Frayed Knot
C-250wk #270
tinob
Response Posted - 03/20/2006 :  08:47:00  Show Profile
Dave/Deb,
Sorry, I can't help you with where you're going but when I had a similar problem it was cured by using some flexible sealer on the threads of the drain and fill screws.
Tom Potter
Response Posted - 03/20/2006 :  18:01:24  Show Profile
Bubba, Did you ever get your lower unit off? I have a service manual for the Tohatsu 8hp (M8B)same as the nissan. If you need me to look up something let me know.
Tom Potter
Response Posted - 03/20/2006 :  18:18:54  Show Profile
Gear Case Disassembly (from the manual)
1. Remove the lower spring pin form the shift rod joint with special tool. (This is the shift linkage joint, I used a small drift punch to knock the pin out)
2. Remove the gear case bolts and withdraw the gear case assembly downward. (There are 4 bolts, 2 on each side near the cavation plate)
That's it! It may be a little stuck, you might have to give it a couple smacks with a rubber mallet. Careful cast aluminum breaks easy! When you put it back together grease the shaft splines with a water proof grease so it won't stick the next time you need to remove it.
Edited by - Tom Potter on 03/20/2006 18:19:51
Bubba
Response Posted - 03/20/2006 :  21:02:11  Show Profile
Thanks Tom. I already did what you said but there's some resistance to pulling the lower unit off. It dropped about an inch and doesn't seem to want to go any further. I was concerned that there might be something else to disconnect. It has sort of a spongy feel when pulling on it - like I'm stretching a hose or something. I'll poke around with it. The manual should be here by the weekend along with the seal kit.
