I installed the ST4000 wheel pilot... think it was about $900. My first control head experienced infant mortality... It was replaced free without hassle... and have had no problems in the last 4 years.
I just finished an install, thanks to Arlyn's help. I got the ST4000 on a sale from SailNet for $799 plus shipping. (I think. I'll check the receipt tonight). It came with a "free" remote, but I found I had to order the cable for it, which was an additional $30 plus shipping. I haven't installed the remote yet .... still deciding just where I want to put the connector so the wire isn't in the way.
So far, it's doing what I bought it for ..... steering while single handing and allowing me to run around the deck taking care of sails, fenders, etc. Also nice for steering during lunch break if the wind isn't too vigorous.
My new Raymarine ST 4000 Wheel Pilot is installed. The bad news is that a drunken sailor (not me "most" of the time) can sail a much straighter course than my new autopilot.
I did the initial sea trial in nearly flat water, no wind, and under power at a slow speed (3 to 4 mph). I swung the compass per the book and found the deviation between the fluxgate compass and the steering compass is within the acceptable parameters specified by Raytheon (i.e. less than 15 degrees). However, the autopilot allows the boat to go off the established heading almost immediately by up to 25 or 30 degrees to port or starboard and back again. Then, it over corrects by up to 25 or 30 degrees the other way. It's doing a "snake" routine alternatively from port to starboard for a total of up to 60 degrees.
I've tried every adjustment specified in the book in various increments ("rudder gain", "rudder damping", "response mode" etc). No luck. Not even the slightest improvement. If I use the + or - 1 or 10 buttons, the autopilot reacts properly but will not hold a heading.
Did anyone else experience this problem? Maybe I have too much lost motion in the rudder? Do I need a rudder sensor (Did anyone else need to install one)?
I'm going to phone Raymarine tomorrow to see what they say.
Blair, the problem you describe was cured on my boat by adjustments to the settings. You might possibly be looking for one setting to fix all...when two or more settings may be at issue and needing adjustment.
i had a problem with snaking (over correct to port, over correct to starboard) with my tiller pilot. turned out it was the rudder that was the problem--so not only do the old rudders suffer tremendous weatherhelm, they require more frequent correction. i installed a third generation rudder and it works terrifically.
Thanks for responses. I phoned Raymarine tech support and was advised to try adjusting 3 settings (rudder gain, response level and drive type) to "2" for a C250. I'll give it a try tomorrow and provide feedback whether it solves the snaking problem.
When did the 3rd generation rudder come out, and how do I get one? Do I need to buy from a Catalina dealer, or can I get one direct from the factory?
Blair.... I just received my "generation 3" rudder, so here's the scoop. I talked specifically with "Dave" at Catalina, he knows what this is all about. You must specify wheel or tiller model as they are somewhat different. I requested a 3rd generation rudder after explaining what year c250, and answering some other questions regarding the current rudder, etc. The new rudder is sold to us as a upgrade for $150.58. BUT..... they forgot to include ( you have to ask specifically for these) #1 new pintles, for the 3rd gen C250 rudder, #2 the Wheel steering Hardware, and #3 the emergency tiller mounting bracket ( this will be different from your old one. This additional hardware was $96.00. So all tols and with freight Catalina will bang you $265.00. But hey it's really worth it. the rudder alone lists in the Catalina book for over $600.00 alone, but they are cutting owners a deal for the next few years until we've all upgraded. It took about 7-10 days to receive everything, pretty darn prompt , I thought.
I guess I got lucky with my recent ST4000 install and didn't have any snaking problems. Mine seems to hold a course OK, and I still have my 2nd generation rudder on. I think you should be able to make the adjustments without a new rudder! I think there may be some play in the rudder during operation that causes the motor to do a little more work, but it's able to hold a straight course.
I also ordered a 3rd generation rudder. It's sitting in the garage waiting for installation. I ordered it directly from Catalina. In my case, though, I asked for the pintles and wheel steering bracket, and these all came installed at no extra cost. My total bill was less than $150 including shipping. I thought this was a hell of a deal, but I'll reserve final decisions on that until I find out it fits properly and all the brackets and pintles don't need moving. <img src=icon_smile_big.gif border=0 align=middle>
I probably need to move the fluxgate compass to a better location, since my boatyard seems to have installed it too close to a big hunk of metal, the engine. The alternator is also probably mucking it. All the adjustments I made to the controller default settings have had zero effect. My autopilot still zig-zags the boat all over the place, which is useful only if I have a submarine tracking me.
I plan to relocate the compass next week and start over again. What adjustments, if any, did you find you needed to make to your setup (such as drive, rudder gain, etc.)?
I didn't need to make any adjustments to the gain and drive settings. The only thing I needed to tweak a little was the clutch. I mounted my fluxgate compass down below in the box below the bottom step. I don't have the problem of an engine nearby, though. I would think the fluxgate compass would be quite sensitive to a huge hunk of metal like that. I had to locate my autohelm motor in the "upper" position, which causes a big disturbance in the magnetic compass on my pedestal. I've even seen my magnetic compass get disturbed by using metal tools nearby (screwdrivers, pliers, etc). As I said, my autohelm holds a steady course under motor, and does well sailing in light winds. If it's starts getting windy and gusty, though, it struggles. I've also tried the autotack, and that works too, settling into the new course without any gyrations.
The manual gave alternate locations for boats with large metal keels. I'd suggest temporarily moving the compass a good distance from the engine and see if the problem lessens or (hopefully) goes away. Maybe you can just run it with the wire exposed and tape it down for testing. Then you can move it about to several test locations. If it doesn't help, might be time to contact Raymarine again -- they should be able to test the compass if you believe it's defective. Also carefully review all the connections and make sure nothing looks like it's not making contact. Since you fiddled around with the settings, there will probably be re-adjustments needed.
My initial control head had a problem...so when I called Raymarine...they first wanted me to open the compass and insure that there wasn't a glob of silicone that caused the fluxgate compass to drag.
Yes, I would think that the compass certainly needs to be well clear of the inboard.
I also had to install the servo motor in the upper left quadrant which places it too close to the binnacle compass. This causes severe error at some points. I have not tried to reswing the compass....but have settled to the reality that the compass is in gross error... and not to be used to set a course.
While a reader may scratch their head at this acceptance...its really not an issue. Courses are now always set by the fixed gps. I do however steer by the compass do to the lag time of gps. So, its a matter of getting on course with the gps...then noting the present compass reading (whatever it is doesn't matter)...and then steering to it.
It seems everyone has had different experiences with essentially the same equipment, and many good suggestions on how to sort out problems. I moved my fluxgate compass to a third new location, and the autopilot now works great under sail alone. However, as soon as I try to use the engine the autopilot goes nuts. So, I'm still getting electrical interferance even though the fluxgate compass is located at least 3 feet from the engine and any electrical cables. The electrical cables closest to the compass are the tachometer and starter moter wires which run from the engine aft to the control panel in the cockpit. I'm going to hold a hand bearing compass next to the fluxgate compass and then power up the engine to see what happens with the hand bearing compass. If it reacts to the engine power I will try a tin foil wrap around the suspect cables as sort of a poor man's RF shielding. I may also be getting some transmitted static electricity from the alternator. What the heck, at this point I'll try almost anything.
Hi Blair Run seperate wire from the positive battery terminal to a breaker for the autopilot. This to avoid electrical noise from your alternator that may exist in your wiring.
I can't believe this is worth the trouble. There's a nice heavy wire from the battery bank to the breaker box that connects to a 12V buss bar. The alternator / regulator from the motor usually connects directly to the battery, so running another wire to the breaker panel isn't going to do diddly in terms of isolating alternator noise.
I hooked my ST4000 to an existing breaker and haven't suffered any unusual behavior while motoring. This is with a normal 9.9 HP outboard, though. The only way to isolate engine noise (if needed) would be to filter the power line feeding the autohelm. I would think any quality piece of equipment would already provide this filtering -- after all it is designed to work in a boat with a potentially noisy power source!
I still think the problem is more due to electromagnetic emissions from the engine. Three feet may not be far enough away for the compass location. Also, make sure any of the wiring to the autohelm doesn't run alongside any of the power cabling from the engine.
What happened with the hand compass with the engine running?
Anyone with a C250 inboard diesel considering installing a Raymarine ST4000 Autopilot take heed. "Quality equipment" is a big question mark right now as far as I'm concerned. Even Raymarine's owner's manual says their equipment may not work correctly on "some boats" due to EMC. You would think that Raymarine's "quality" equipment would be designed to work properly with any modern diesel engine (mine's only 3 years old). I can't believe that Yanmar installs alternators which are THAT noisy.
Here's what I've tried:
1) I Moved the fluxgate compass to no less than 6 differnt locations on the boat both fore and aft everywhere from 3 feet up to 7 feet away from the engine. (7 feet SHOULD be enough.) None of these different locations has made the slightest bit of difference. I made sure compass wiring does not run near any power cables.
2) Installed 2 "ferrites" on the compass cable at the control unit, which were subsequently sent to me by Raymarine. Did not help in the slightest.
3) Raymarine's fluxgate compass cannot be made maintain a match to the steering compass, no matter what. It's always from 10 to 20 degrees off even with no engine power running.
Now, I'm going to try running a seperate wire from the battery to the circuit breaker panel switch for the autopilot. If that does not work I will run the seperate wire from the battery directly to the autopilot with a seperate switch, NOT through the circuit breaker panel. If that doesn't work I will try a seperate battery isolated from the boat's power loop. If that doesn't work then I will be sending an autopilot back to Raymarine Corporation. Life is too short.
