Here is a question for those with an aptitude for electrical conections. I seem to be lacking in that department. My new sled contains a charger for the battery that is set up for connection to a 110 outlet. How do I use the 30amp dock side power to charge the battery
Normally, one would connect a shore power cord between the 30A dock outlet and the boat's power inlet. From the power inlet, the wires should go to a breaker box inside the boat which would feed the 110V outlets.
Assuming your boat is not set up for 110V, you could run a cord from the 30A dock outlet into the boat where you would plug in the charger. Depending on your power cord, you may or may not need an adapter to be able to plug in a 110V plug.
A little clarification. There is a male plug for 110V in the stern that runs directly to the Charg Pro battery charger and then to the battery. Is it safe to run 30 amp directly to the charger via a plug adapter?
Yes, an electrical device runs on its design voltage and only uses as much current (amps) as needed. You could have a 100 amp circuit and if it was 110-115-120 it would be fine. Your charger will only drink what it needs. You might want to buy a book, this is very basic stuff. Several people recommend a a marine wiring book fairly often, I assume it has a shore power section in it.
I would like to second Frank's excellent suggestion you get a study a book on boat electrical systems. I recommend Don Casy's "<b>[url="http://www.amazon.com/gp/product/0070366497/002-4853760-1229631"]Sailboat Electrics Simplified[/url]</b>." <center> </center> There are additional issues (<i>a.k.a. potential for big screw ups</i>) associated with boat electrical systems which are of little or no concern in one's day to day use of electricity in the home.
