 deck cleaning
zebra50
Initially Posted - 05/23/2006 :  11:44:34  Show Profile
Does anyone have suggestions for cleaning the stains left by birds and other creatures on the cockpit and cabin deck? I have tried "Lime Away" and it really didnt do much to rid the stains.
Jay
Papa's Boat II
250WB #370
Blog:http://zebra50-boilingpoint.blogspot.com
bear
Response Posted - 05/23/2006 :  11:54:38  Show Profile
Sunshine, it took away leaf stains on "Brandy".
moserd
Response Posted - 05/23/2006 :  12:15:14  Show Profile
I accidentaly spilled fuel on the deck AND walked in it with my boat shoes (which by the way WILL disolve in fuel). This made a big mess which I could not get up any way, any how. However it seems that the SUN has taken care of what I could not, after about 4 months the stain has 'gone away'!
Good luck.
Don
Response Posted - 05/23/2006 :  13:51:43  Show Profile
See my previous posts on Ultra Brite toothpaste. I cannot speak highly enough of the ease and quality in using it. Use a stiff nylon brush on non-skid, a wet rag on the stainless and rinse thoroughly(sp), you will be amazed!! It is easier than raising the main, and eco friendly.
Edited by - 528 on 05/23/2006 13:53:31
Response Posted - 05/23/2006 :  13:58:26  Show Profile
Sunshine does work and beyond that good wax protection will help avoid the stains. My struggle was the nonskid that never got waxed and finally after using Starbright cleaner/sealer for non skid, life has gotten better.
Grit doesn't lodge in the nonskid and grow mildew after the sealer and I've detected no slippery issues.
Tom Potter
Response Posted - 05/23/2006 :  20:06:29  Show Profile
Thanks Dave, I'm gonna have to give that tooth paste trick a try.
frog0911
Response Posted - 05/23/2006 :  20:28:45  Show Profile
In lovely Norhteast Florida the sea gulls, turkey buzzards, osprey's and spiders do there best to make PennyII look like an outhouse. The best and cheapest I have found requires a trip to Wally World were I purchase the cheapest liquid dishwashing soap. Then blend one cup with one gallon H2O and a stiff brisle brush. Apply to deck, allow to sit for a couple of minutes then brush and rinse. Another item that a lot of people use around our neck of the woods is a tolet bowl cleaner called "The Works". We pick it up at the dollar store. Sponge it on and rinse. Be sure and wear rubber gloves. I have use it to remove the water stains at the boot stripe. Works better than FSR and a great deal cheaper. For the stains just apply to sponge wipe and rinse. Stains gone.
Edited by - frog0911 on 05/23/2006 20:29:50
Response Posted - 05/24/2006 :  10:21:22  Show Profile
Tom, let me know what you think. I suspect there are skeptics out there because it sounds so off-the-wall. It really is the only thing I use to clean with now.
Bay Tripper
Response Posted - 05/30/2006 :  19:31:20  Show Profile
I have used Chlorox to clean to non-skid and it removed the leaf, bird deposit, and other stains.
I use it straight from the bottle and use a brush to work it in and then wash it off.
Tom Potter
Response Posted - 06/16/2006 :  20:57:59  Show Profile
Dave, I broke down and bought a 97 cent tube of ultra bright tooth past and found a old tooth brush. Your right! it cleans those hard to clean spots and smells good afterwards.
Response Posted - 06/17/2006 :  06:29:05  Show Profile
Tom, thanks for the report. If you use a large nylon brush, you will clean areas much easier and faster, leaving alot more time for sailing. I use a screw-on pole head for the whole deck, it is amazingly fast. (and you won't grab the wrong brush in the bath )
Spread the paste, err, word!
