 New Switch Panel Project Completed
Cate
Initially Posted - 06/14/2006 :  15:30:24  Show Profile
One of my major upgrades for this season was to replace my original switch panel (1983) with a new one from CD. I ordered the panel that they said would fit my orginal opening...
http://www.catalinadirect.com/index.cfm?fuseaction=product.display&Product_ID=618
BUT...no-o-o-o. Quick trip to Lowes for a jigsaw.
I will say all the hardware CD supplies were excellent and top quality. The installation directions were also very good. We were able to clean up a lot of the wiring mess created by POs. Since there were more switches we were able to give each device it's own switch.
The entire project took about 5 hours including the run to Lowes for a jigsaw and cutting a bigger opening.
The miracle of this project was connecting the new 4-plex mast wiring. (I had previously installed a 4-pin deck connector). We didn't know what wire went to what on the mast, but the places we plugged into on the switch panel turned out to be the correct connections FIRST TIME! It was great way to end the project with a small miracle.
We are almost ready for overnights. Last project will be installing two new Trojan AGM Grp. 27s batteries. My electrcian friend says I don't need a switch. Hmm.
1983 C-25, Standard rig, swing keel
djn
Response Posted - 06/14/2006 :  16:50:46  Show Profile
Hi Cate, I am glad to hear it all went well. I need the possitive stories as I am going to be doing the same thing this weekend. Cheers.
Response Posted - 06/14/2006 :  18:08:25  Show Profile  Visit OLarryR's Homepage
Cate,
Congratulations on completing the project ! I am not yet ready for that stage...but the day is coming. Right now, the mast is rewired, the lights all work but I have 3m 5200 in place of the old deck connector. The new deck connector is laying in the cabin and rewiring to the old switch panel is next on the agenda. Not yet ready for the switch panel but ....your project completion gives encouragement.
Enjoy your overnighters !
Tom Potter
Response Posted - 06/14/2006 :  19:17:24  Show Profile
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Cate</i>
<br />We are almost ready for overnights. Last project will be installing two new Trojan AGM Grp. 27s batteries. My electrcian friend says I don't need a switch. Hmm.<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
The key to hooking up batteries without a switch between them is making sure both batteries the same size and age. I don't have a switch either. I have a electric start with a hand start backup. Stayed aboard 7 days running off those two batteries, no problems starting motor with elect start. If you have a inboard or no means to start your motor without battery power then I would put a switch. But as long as you can start by hand there should be no problems hooking up without a switch.
mcollard
Response Posted - 06/14/2006 :  20:28:29  Show Profile
Cate, did you install the new panel in the original location? I need at least a new switch, but to tackle the rat's nest of wire I need to first lose 150 pounds so that I can fit in the lazarette compartment.
Response Posted - 06/15/2006 :  02:18:34  Show Profile  Visit Frank Hopper's Homepage
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by mcollard</i>
<br />Cate, did you install the new panel in the original location? I need at least a new switch, but to tackle the rat's nest of wire I need to first lose 150 pounds so that I can fit in the lazarette compartment.
I am 300 pounds and the trick for me on my 82 was too take out the bulkhead between the quarterberth and lazerette (remove quarterberth cushions too), slide in the sail locker that way and sit on a couple of throwable cushions. I must have done it a half a dozen times as I mounted my battery charger and rewired the power panel, ran new wires for a new stern light, speaker wires, etc.
Response Posted - 06/15/2006 :  06:37:40  Show Profile  Visit Champipple's Homepage
We actually removed the bulkhead entirely to cut it. Took all of 10 minutes. I was small enough to squeeze my behind into the sail locker to wire everything though.
dw
Cate
Response Posted - 06/15/2006 :  08:38:30  Show Profile
Yep. I was tucked into the lazarette while my electrician buddy worked on the other side. We detached the old panel with most wires intact and pulled it through the opening. In order to pull it through we did have to disconnect some of the shorter wires and label them.
panhead1948
Response Posted - 06/15/2006 :  13:11:31  Show Profile
It must be that time of year. I did my replacement last week also. Now I have to run the wire from the mast plug to the panel for my deck light. and I'm all done.
djn
Response Posted - 06/15/2006 :  17:39:45  Show Profile
Yep Panhead, I think you are right. The only think stopping me from completing my rewire is getting my fat #(& into the sail lock to unscrew the bottom row of screws. I installed the through deck fittings today. Cheers.
