<font size=5>A couple of weeks ago I unstepped my mast to add a swivel block for the topping lift. When I did, I found a broken sail slug on the main. My problem is that the slugs are sewn onto a kind of tether which in turn is sewn through the grommets. I never did really like the system and was wondering if anyone sees a problem with just replacing them all with some that are easily attached (say, with tie weraps) instead of sewn on?</font id=size5>
Ben- There are a few types of sail slugs available. Most use a flat shakle with a plyable platic protective shield. My new main came with slugs that were too fat for the mast and I replaced them all including the sewn on one at the top of the sail (that was the only one sew on). Once I got the courage to cut the "tether" all was fine. I use the plastic ones with the stainless eye. I'm not sure what size either 5/16" or 3/8". They only cost about $1 (without the shakle and plastic protector). The shakles come with the protectors for about $1.25 each.
Do I understand you correctly -- that 1/2" slugs proved to be too fat for your internal track? My current slugs are dying of old age, and I was planning to replace them with 1/2" ones, as that appears to me to be the nominal size of the luff groove. I'd sure like to know which size you found to be too large, and why. Thanks!
Leon - I won't be out to Peregrine till Thursday. I'll be glad to measure them then. Sorry I won't be out there sooner. Maybe some one else has the correct size.
