 Mast Climbing Apparatus in NY/CT
bmelchionda
Initially Posted - 12/16/2006 :  06:02:04  Show Profile
Hello all! My jib halyard is stuck at the top of the mast and I can not take down my jib for the winter months. The true type mast climbing apparatus's are fairly expensive and I wouldn't attempt climbing up myself.
The boat is in Bridgeport, CT....does anyone have a mast climbing apparatus they would be willing to lend me? I can pick-up if you are local or pay for shipping if you are willing to send via mail. If you are local, heck - you are welcome to spot me when it is convenient for you.
Thanks!
'86 Catalina 25 Tall Rig
Response Posted - 12/16/2006 :  08:40:37  Show Profile  Visit britinusa's Homepage
Any idea how it is stuck (jumped off sheave etc.)
Do you have a 2nd halyard up front?
paul
Response Posted - 12/16/2006 :  09:11:13  Show Profile
Isn't it a lot easier to take the mast down?
bmelchionda
Response Posted - 12/16/2006 :  11:04:12  Show Profile
I do not know how it is stuck, but it feels like it came off the pully as it will not budge...at all.
JimB517
Response Posted - 12/16/2006 :  12:16:21  Show Profile  Visit JimB517's Homepage
It is easy to hoist someone under 150 lbs up the mast using the remaining halyard and a bosuns chair. I hoist two blocks up the mast, one block on the chair and 100 feet of 1/2 nylon rope in a 3 part block and tackle. I can hoist my wife with arm power only. Without the blocks, you can use a winch.
BUT
There is no way you should do this if your boat is on the hard.
tinob
Response Posted - 12/16/2006 :  12:37:55  Show Profile
Brian, Happened to me a few years ago and it turned out to be the crumbling of the sheaves. Over time the retaining walls of the sheave wear out and or fail subject to the effects of solar rays deteriorateing the plastic that the sheaves are made of. In any event an eighty something Catalina's sheaves are suspect and should be checked and if the mast is coming down to inspect them just bite the bullet and replace them. If your season has ended I'd recommend dropping the mast and have the CD sheave replacement kit handy. To use the other haylard to hoist someone up the mast on a sheave whose counterpart has crumbled is asking to possibly strand a person up the mast.
Val on the hard DAGNABIT, # 3936, Patchogue, N.Y.
sweetcraft
Response Posted - 12/16/2006 :  13:46:49  Show Profile
I made a center separator of aluminum for a replacement of the masthead small separator of the sheaves. Friends 86 TRFK was having the cable halyard get stuck on a regular basis so after lowing the mast discovered the cable was able to get by the separator. I made one that was longer and also for my 79. Used the original for pattern of the pin holes and reinstalled with the mast down. Mast down is only way to assess problem and make changes. Too cold to climb mast anyway.
johnsonp
Response Posted - 12/16/2006 :  18:35:36  Show Profile
<font color="blue"><font size="4"><font face="Comic Sans MS">This is how they check there mast down under.
paulj</font id="Comic Sans MS"></font id="size4"></font id="blue">
djn
Response Posted - 12/16/2006 :  19:32:27  Show Profile
You might want to drop the mast. If there is a problem, you need to look over all the shives to make sure you don't have future problems. Also if the halyard you use to go has problem, how would you fix it. Cheers.
tinob
Response Posted - 12/17/2006 :  08:05:03  Show Profile
AND...then they do the other side of the mast
Chris Z
Response Posted - 12/17/2006 :  09:10:58  Show Profile  Visit Chris Z's Homepage
My big concern with this picture above is the position (COE) of the beer cooler. That is too risky to do and take the chance of loosing even one beer.
HeelinPatrick
Response Posted - 06/25/2009 :  13:49:25  Show Profile
Jim,
Why do you say not to ascend the mast if the boat is on the hard. I take it because it could slip on the trailer or stands? Have boats been tipped over by doing that or something??
Response Posted - 06/25/2009 :  14:28:16  Show Profile
I don't know of any, but why be the first. If you fall 50' to a hard surface, you have a 50% chance of survival (lots of variables, but that is the statistical value. You would only fall 40' - 45', so your chances would be slightly better. Boats can move and things can fail, that is why we wouldn't do it. Lowering the mast is a simple solution that is safer, allows a more thorough inspection, and an easier repair. On the water, I have gone up the mast for a quick repair, but you are better off on the ground if you aren't sure of the problem. Replacing the sheaves is easy if one halyard (preferably using the other as a safety) isn't supporting you.
Renzo
Response Posted - 06/25/2009 :  16:14:22  Show Profile
Other than the issues of falling, suspending a 150 lb.++ person at the top of the mast while the boat is on the hard, and can't heel, puts unusual amounts of stress on the compression post and the hull if the weight gets off center. Think of the mast as a very long leaver, a small amount of pressure to the side at the top results in extreemly strong force at the botom.
millermg
Response Posted - 06/25/2009 :  22:51:22  Show Profile
Ok, here's the trick the old salts in my marina taught me. I actually have to do this tomorrow night to replace the anchor light, so hopefully I'll be a bit saltier the next day. They hoist the top of an aluminum extension ladder up the mast w/ the spin halyard, and tie the feet of the ladder secure to the bow cleats or pulpit. If you're brave and have really calm water, you can simply climb the ladder. It's very secure. If you're not, use the jib (or in your case, maybe the main) halyard and have someone 'belay' you up w/ a bosun's chair. If you do fall somehow, the chair will catch you. And you can work pretty easy w/ two hands. At least that's the theory. I'll let you know how it works out soon!
Response Posted - 06/26/2009 :  05:43:01  Show Profile  Visit Prospector's Homepage
Good idea Miller, but with his boat on the hard he may be even better off to rent a bucket truck. Park beside the boat, go up in the bucket. If you know an electrician or tree trimmer you may even be able to get a one-time only free use.
Response Posted - 06/26/2009 :  06:25:33  Show Profile
In the spring the boat next to me on the hard was a Capri25. They had run a thin messinger line up the mast in order to remove the halyards for the winter. The line was thin enough that it had jumped the sheaves at the top and had jamed. They used the ladder technique as Miller describes above. They used a wood ladder so as not to Mar the mast surface. It worked very well.
Response Posted - 06/26/2009 :  09:25:54  Show Profile
I know several people who have had older relatives (fathers) suffer falls from distances far less than our masts. In every case it caused significant ongoing life changes for them. I can see having to climb the mast if you are out to sea and that is the only option. With a 25' boat and a stepped mast I do not see any cause to climb the mast when I can use a simple gin-pole and lower the mast in 10 minutes. Why even take the risk? My two cents.
Response Posted - 06/26/2009 :  10:10:18  Show Profile  Visit Prospector's Homepage
You're probably right Nauti, but with the right equipment, and a little common sense, climbing th emast can be pretty darned safe. In my trip up it I had an ascender, a full harness, and a safety man on the ground.
Now climbing to the treehouses we built as kids - that probably qualified as dangerous. I also remember long jump competitions off neighbourhood roofs. Not sure if I would survive that unscathed anymore. Then there were the hay lofts we used to run and jump out of, the train trestles, the underflow dams we dove off of...
Yup, life is full of dangers. Wish I was 12 again.
Renzo
Response Posted - 06/26/2009 :  11:15:19  Show Profile
<br />You're probably right Nauti, but with the right equipment, and a little common sense, climbing th emast can be pretty darned safe. In my trip up it I had an ascender, a full harness, and a safety man on the ground.
Yup, people bounce pretty good at 12 years old. And at 20 yrs old they bounce back fast. Older than that they tend to fall flat and have lasting repercussions. And when you are over 40 and take a big fall you tend to just lie there.
Response Posted - 06/28/2009 :  13:45:48  Show Profile
I agree with Randy. Beside,it will take as long to properly secure the ladder as it would to simply drop the mast.
Response Posted - 06/29/2009 :  13:19:50  Show Profile
I'm reasonably close to you and understand the local yard/marina costs. However, I would eror on the side of safety and take the mast off and inspect. I had to replace all sheaves a couple of years ago and while the mast was off checked the standing rigging and all cotter pins and re-taped. At a minimum have your local yard send someone up to inspect, but my guess is that you will need to take the mast down regardless, so you should take advantage of the terrible weather we are having (In tne NY/CT area) and unstep the mast now. Needless to say, when checking make sure that the running rigging is also in good shape.
